Has anybody successfully managed to cure engine non start. Runs for 20mins,cuts out,won't restart unless you put a new plug in!
Done the usual,temp sensor,carb,fuses,wiring,fuel etc. It just kills the spark plug! Could the coil be at fault? or the ecu, weird as the spark will jump 2 inches from the end of the ht lead! Used Ngk and Bosch plugs, could I be using wrong plug!
