I had a guy offer to buy my bike at the start of month. We arranged for him to come to my house later that month.
Two weeks ago I managed to track down all the gremlins affecting it after I had removed engine to change belt and variator ( Bad spark , blogged jets {twice}; spark plug wire pulling out of spark plug cap)
Got it all sorted , fired up first push of button. Only issue was to adjust the connection of throttle on carb as it was idling way too fast.
The guy came around this week to actually see bike. I went out that morning, popped in the battery which is kept in house and fully charged, and the bike would turn over, but not fire up. ( It was -15 that day)
He said he wants to buy the bike but I told him I wont sell it to him unless he actually sees it run like I promised.
Went out today and started troubleshooting. Battery was topped up, and I get a spark on testing plug (new) being grounded to engine case. (tested and wire and cap are tight)
But when I crank engine to check fuel, none comes out.
WTF????? Just shoot me now !
So I pop vacuum line off the manifold between carb and head, and blow into it to see if it has a leak. Strong resistance, so no leak.
NOTE : I did the EVAP removal several years ago and replaced all vacuum and gas lines then with quality ones.
If I suck on the vacuum line, gas flows from the fuel line, so petcock is fine.
I replaced the rubber manifold between carb and head as I had a spare. (
I had to reuse the gasket which had no tears or damage. )
It still wont create a vacuum and allow gas to flow?
Any ideas?
I considered the fact that I didn't have gasket sealant on it might have been the issue , but I ran it like that for years with no issue.
Another item. I pulled the rear hose off the carb and tried to start it with Quick Start Carb spray. It wouldn't start on it either? Do I have carb and manifold issues?
⚠️ Last edited by duane1 on UTC; edited 1 time
