Hi guys, can anyone tell me is it possible to mount LED rear light from '19-'22 GTS 300 to 2015 model? Is it real that im the first one wondering how to do this 😅
LED tail light
LED tail light
LED tail light
LED tail light
have you tried?
Vespa Sei Giorni 2020
Hi,
I have done it on my 2018 GTS. You need the plastic bracket where those two metal tabs will hold. It bolts on two upper bolts (on 2015-2018 models the lamp surround is held by those bolts). You will also need to modify the connector or buy a conversion cable. Here is a link to that plastic bracket: https://www.scooter-center.com/en/tail-light-bracket-piaggio-vespa-gts-125-zapma3700-vespa-gts-hpe-300-zapma3600-zapmd310-vespa-gts-super-125-zapma3700-vespa-gts-super-hpe-300-zapma360-zapmd3100-vespa-gtv-hpe-300-zapma3602-zapma362-zapmd3102-1b006418
I am not sure now as it was a year ago, but I think I had to cut that small pin off otherwise it didn't fit, there might be a hole for it on newer models.
I did not try yet, but im thinking of giving up. I will try to sell it and buy aftermarket with all parts compatible.
Thanks for answers, have a great ride!
[ Time: 0.0212s ][ Queries: 4 (0.0042s) ][ live ][ 343 ][ ThingOne ]
