Hi all
A slightly left of field question but here goes ...
I've recently fitted a universal fuel sensor from LSK Electrics - basically it's a pressure transducer and convertor that measures the head pressure in the fuel line and converts to a signal for a fuel gauge.
https://www.lskelectronics.com/store/FuelGaugePro-Universal-Sending-Unit-kit-p286978985
I'm wanting to keep the instrumentation as minimal as possible so thinking of getting the SIP Speedo 2.0 as would like the CHT temp etc as well.
However as these don't display fuel level (for a Rally 200) was thinking I might be able to use the RPM display instead.
Just thought I'd check if anyone could clarify what the actual signal type used by the tacho and if I could convert the fuel level signal?
I suspect the rpm signal might be a voltage and the fuel level is a resistance. If so ideally at 100% fuel the tachno would display say 10,000, then for 50% 5000?
Any suggestions about how I might get this to work would be terrific.
My scooter is setup with 12V dc.
Thanks so much
- Matt
