2013 Beverly 350
2013 Beverly 350
Hello, I'm having a weird noise while starting my Beverly.
The noise is coming only when the starter is turning, and is happening only when it's cold outside AND the engine is cold also (if it's cold outside, and the engine is warm, there is no noise).
I'm thinking it's either the starter, or the sprag clutch is making weird noises when the engine oil is cold.
Did somebody had this problem, or any tips to help?
The noise in question: https://youtube.com/shorts/FoZremAkYLI?feature=share
@breaknwind avatar
Red Devil SH150i (11,000)
@breaknwind avatar
I had that noise with my 2014 BV. Although it was half as loud. Sold it with 46,000 miles on it. If it's a grinding noise, you've got a problem.
2023 Vespa GTS 300
2023 Vespa GTS 300
Starter is wearing out. Replace the start components. You only get so many starts out of them.
That just sound like a bearing in the starter that doesn't like the cold. Presumably a phosphor-bronze one that could do with a tiny drop of 3-in-1.
That's also the easiest and cheapest thing to check.
I doubt it's the starter wearing out as such - that'd be the brushes if anything which would lead to intermittent starts, not squeaky ones.
2023 Vespa GTS 300
2023 Vespa GTS 300
When bronze bearings start squealing, they are worn out. Oiling them will stop the squeal only temporarily. Permanent fix is replacement.
Rebuilding starters requires a good deal of skill plus access to parts. For most, replacing the entire assembly is the better alternative.
2013 Beverly 350
2013 Beverly 350
I was worried that maybe the sprag clutch was starting to acting out. I will rebuilt the starter, or order a new one. Thank you for the replies!
@mr_f avatar
2013 BV350
@mr_f avatar
2013 BV350
No problems here; however, I'm paying particular attention to this topic. Has any one asked Robot yet?
[ Time: 0.0094s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
