Hi,
I've been having trouble getting my 2017 Primavera 50 to fire. There's plenty of battery. Following a tip I found in some corner of the internet, I detached the air pipe from the air filter and blasted some carb cleaning spray up the pipe in the direction of the carb.
It started straight away, but a couple of days later I tried to start it again and it wouldn't fire. So I did the trick with the carb spray again and it sure enough started...
So my question is, in light of what I've said, what do you think the problem is likely to be, and what would be a more permanent fix?
Thanks!
Tim
