Hello. Old guy here. Other than my new BV-400 may need to " relearn" how to run/idle -after battery cables are removed for a few seconds-any problem with anything else if I disconnect the battery to install the leads for a SAE charging plug ( battery tender). I realize I might be able to use small jumpers so no connection is lost while I have the battery bolts out but my hands shake and I certainly don't want to slip and arc. Any replies appreciated. Thanks
Well I managed to use a couple small jumper wires w/alligator clips, so nothing lost. Plugged in the battery tender. Waiting for weather to cooperate now.
