First time post but have been following and reading others post for the last year or so.
I've had my 1964 Allstate for about 7 months now.
Specs
150cc
12v Vape ignition
SIP 2.0 road
Spaco 20/15D
Jets
MJ 100
Air Corr. 120
Emulsion tube E1
Idle jet 42
Start jet 60
My question is about jetting with the SIP exhaust. After installing the exhaust I noticed a big difference in power. But am afraid of running to lean. I was curious if anyone here with similar set up has jetting set up that works? I did try a 102 Main jet but it sputters upon take off and if I'm at 1/4 or 1/2 throttle but it cruises at WOT. When I go back down to 100 Main jet it doesn't have the sputter. But the spark plug looks lean after a 15 minute ride with the 100 MJ.
If I do need or do go up on the MJ what would help out with the transition from 0 to 1/2 throttle sputter?
Any help will be appreciated
⚠️ Last edited by Jz54oval on UTC; edited 1 time
