2004 Piaggio LT 150 - its bogging down on quick acceleration (aka applying twist of wrist quickly) at all speeds (from a stop or while at high speed, mostly on hills). If I take it up to speed slowly it seems to be mostly fine.
Actions I have taken:
1) pulled carb and cleaned it TWICE both jets and inside of float bowl
2) changed fuel line
3) checked fuel filter, looks good - I pulled petcock to do this
4) air filter is fine
5) no vacuum leaks, tested with carb cleaner
6) removed full EVAP system (just in case it wasn't working properly)
Seemed to be better but then I put 87 grade unleaded in the tank and my problems immediately started again as I left the gas station. So I drained the fuel from tank and float bowl of carb. I put in 90 grade unleaded (that's the highest I have in my town).
But I am still getting the bogging down on quick wrist acceleration at all speeds? I am at my wits end here. Any help would be much appreciated.
⚠️ Last edited by shanerrr on UTC; edited 1 time
