@coastalviews avatar
P125X
P125X
So ive had the 177/road2/26.26/drilled heart, kit up and running for the past week as I break it in with the following jets:
Idle 52-140 - Turned idle up, mixer screw all the way in, backed it out until it no longer affected the rpms, lowered the idle.
AC140 - i was using a 120 up until today.
BE4
125mj
Starts up on the 2nd or third kick with no choke, maybe just a slight twist of the throttle, then idles by itself.
The throttle is very responsive, and crisp off idle, but once I start getting on it, I get sputtering/spluttering(sounds like its blowing a raspberry) through 1/4-3/4 or so. I havent even gotten it to WOT since im on 35mph city streets. The plug looks dark brown, and the air filter has fuel on the inside of it.
I don't mind running a little rich if it means a cooler engine, and less chance of a seize. This isn't a performance build. But the noise sounds like crap.
I was thinking maybe stepping down the mixer, since I have yet to hear anyone running a 177 with an AC larger than the 140.
Any ideas where to start?
⚠️ Last edited by coastalviews on UTC; edited 1 time
@peeteboy2 avatar
1980 P125x 2002 Bajaj Chetak
Location: Southern California, but Crete is where my heart is!
@peeteboy2 avatar
Your idle is the same as your air corrector? Maybe you know something I don't and that would explain my jetting problems
P125X
P125X
Nope! Just a bonehead mistake. Sorry i couldnt help ya! Laughing emoticon
Jet Eye Master
Jet Eye Master
Put the AC120 back in. Reduce the MJ from 125 until the raspberry sound goes away.
P125X
P125X
I put the 120 back in and stepped the 25 down to 23. It seemed to run slightly better. I noticed it's sputtering when I'm barely to 1/4 throttle, but can roll the throttle right through it, and the sputtering disappears.
[ Time: 0.0101s ][ Queries: 3 (0.0039s) ][ live ][ 343 ][ ThingOne ]
