@chippieboy avatar
1965 VBB2
@chippieboy avatar
1965 VBB2
This is a sort of spinoff of this past post:Leak....cylinder to cases
I just received my new stock cylinder including a wrist pin, piston and a set of rings. I was looking at the new piston and it has one less port than the old piston. Now I am not sure what is the correct one to use. Is the old piston wrong and the new piston is right or visa versa?
Old Cylinder
Old Cylinder
New cylinder
New cylinder
Old piston
Old piston
New piston
New piston
@oopsclunkthud avatar
1:3
your old piston was for a "three port" cylinder that has a third transfer port opposite the exhaust port.
your new piston and cylinder are as they should be.
@chippieboy avatar
1965 VBB2
@chippieboy avatar
1965 VBB2
Wow, and I thought that scoot ran fabulous with the incorrect piston. Curious to see how it runs with the correct piston. BTW which way should the arrow point?
And, thanks for the info.
1:3
the three port piston will run just fine in a two port cylinder. it's not "correct" but will work.
the arrow points toward the exhaust port.
[ Time: 0.0108s ][ Queries: 4 (0.0037s) ][ live ][ 343 ][ ThingOne ]
