@kudu avatar
1979 P125X, 1983 P125X America
@kudu avatar
So, last night I was scooting along on my 79 P125X with every light working and the next moment nada... no headlight, brake light, turn signal, speedo light, nothing! Horn still works, but I have not had time to check the actual bulbs.
I am sure I'll get to the bottom of the issue, but before I start chasing my tail for a couple of hours, I was wondering if anyone else has had the same and is able to offer some insights. Ignition and rectifier are new.
@mjrally avatar
@mjrally avatar
Horn I'm guessing is off a battery, lights off the stator? If so, I'm guessing a power wire unplugged somewhere along the line (junction box, rectifier, keyswitch).
Jet Eye Master
PX221 MHR heavily tuned, PX200 O tuned, PX181 M1XL tuned, PX166 tuned a bit and some motorbikes
Jet Eye Master
If its a euro P, either the regulator failed or the grey/green wires are unplugged from the regulator.
Could be a short circuit anywhere on the grey wire but then you'd be really unlucky.
@kudu avatar
@kudu avatar
Sorry, I omitted from the original post that my PX is one without a battery...
@mjrally avatar
@mjrally avatar
No problem. Like Jack said, start looking for unplugged wires.
@kudu avatar
@kudu avatar
Update: Spent lunch swapping out the rectifier with one that was known to work and (touch wood) it seems to have solved the issue.
What struck me was the difference in size between the BGM one that came out with less than 100 miles on it and the large one that I had fitted before my Norway trip (3000 miles). The only reason I replaced the latter was that the smaller BGM one came with the contactless ignition, and I had assumed that they would be better together...
[ Time: 0.0104s ][ Queries: 4 (0.0022s) ][ live ][ 339 ][ ThingOne ]
