@wingnut33 avatar
GT200
@wingnut33 avatar
GT200
Hi All,
here we go,
I now have a GT200 53 plate recovered from my dad, with the original Walbro carb that is no longer available. i have running issues and have stripped the carb and its a bit to be desired inside... the intraweb isn't coming up with any clear ideas for an upgrade so I thought of you lot . any ideas of the options ?
it has a PM tuning pipe and a Malossi pot and piston but not sure of the CC.
any help would be appreciated
I'm not frightened of spending money but don't want to go silly
many thanks in advance Wingnut ...
@nitro200 avatar
2005 Vespa GT200
@nitro200 avatar
2005 Vespa GT200
I have a GT200 and realistically the carb to get is malossi 34 with a accelerator pump the price is around $430 from scooterparts.com
In the USA, looks like you live in England you could probably find one closer to you
It's a steep price and I'm still saving for it and it appears to be the only option the GT200 also uses the keihin carb there available and pricey but for a extra $50 for the malossi It's a no brainer.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
Is there a reason you don't want to clean up the carburetor and reassemble it? It's not likely to be necessary to replace it. I work on antique motorcycles and regularly rebuild carburetors that are 70+ years old. Often they've been sitting unused for 20, 30, 40 years and are pretty grungy inside. I'd bet if you cleaned it all up, it would perform just fine and you'd save hundreds of dollars.
@wingnut33 avatar
GT200
@wingnut33 avatar
GT200
Hi caschnd1.
i have stripped and sonic cleaned the carb and the housings came up fairly clean including all galleries washed and blown through.
i think the issue is the condition of seals etc and they are no longer available. it looks like the carb was used for a couple of years then discontinued as mine is an early one this is my problem
Thanks for your replay , Wingnut.
@wingnut33 avatar
GT200
@wingnut33 avatar
GT200
Hi Nitro200,
thanks for your reply,
with my first search it looks like Beedspeed in the uk do the Malossi 34 kit for about £400 i need to contact them and make sure its a direct fit for e.g. as it comes with cables etc
i have starting issues and low power so a bit annoying. I've done a fair refurb so its already had a new CDI, choke solenoid (comes off choke ok when it warms up), iridium plug, carb strip and clean, vacuum fuel tap,
this was all required as it was in storage for years
Manty thanks Wingnut.
@nitro200 avatar
2005 Vespa GT200
@nitro200 avatar
2005 Vespa GT200
Hey wingnut your bike looks almost like mine except yours is in blighty and mine is in southern California your a brave man for riding that in the weather you get I was born and raised in Bolton lancashire but only rode motocross and trails my gt200 has never seen wet weather if your looking to add more performance parts I've done a bunch of work on my bike and will gladly share my knowledge of what's good for your bike
Dress for the ride not the crash
Nitro200.
⬆️    About 9 months elapsed    ⬇️
@sglaw avatar
Vespa GT 200 L 2004
@sglaw avatar
Vespa GT 200 L 2004
Just out of interest, has anybody fitted one of these:
NARAKU- 30mm (diaphragm operated) for Piaggio 125-250cc
[ Time: 0.0092s ][ Queries: 4 (0.0023s) ][ live ][ 343 ][ ThingOne ]
