I went to install my new cylinder and noticed a bit of rocking. Left to right. Since I squared my case deck with a brick of glass I am pretty confident that is square and true. I tested the surface with other cylinders and it seem good.
I assume that a good $100+ caliper will suffice as a straight edge. I noticed the same high spots with the straight edge and the same behavior on the deck of the cases with the cylinder in question. My question to the forum is: I have access to a good Bridgeport mill at work. I am thinking of milling the cylinder mating surface true but it appears that this surface is not milled but squared by other means. This is the 3rd goofy cylinder I have received from the online vendor and I am reluctant to try again. Any ideas.
