Vespa GTS300
Vespa GTS300
Hello,
I recently purchased a new GTS300, Classic, which comes with Bluetooth as optional. I purchased both the module and the installation kit separately, but can't find any installation instructions. Would anyone of any instructions or videos I can look up? Thank you in advance.
Best.
Vespa GTS 300
Vespa GTS 300
The Vespa Mia module is mounted with the installation kit behind the glove box or behind the maintenance flaps. Unfortunately, I don't have detailed instructions, so I can't describe the exact position or what needs to be removed.
2019 GTS SuperTech 300 HPE w Malossi kit
looking at this video at 12:25 I think I can see it installed. GermanGTSDriver does that look like it to you?
Vespa GTS300
Vespa GTS300
Thanks so much, this might help.
and I forgot to say, if you're an android user then you can try my app instead of piaggio's crap app https://play.google.com/store/apps/details?id=com.steelbytes.vespasnoop
Vespa GTS 300
Vespa GTS 300
Yes.
⚠️ Last edited by GermanGTSDriver on UTC; edited 1 time
Vespa GTS300
Vespa GTS300
Already installed the app 😂, can't wait to try. The video actually pointed me in the right direction, I thought I'd be fastened to the back panel, behind the tag module, left. It looks to be under the coolant expansion tank, on the box itself, right. Thanks again.
Vespa GTS300
Vespa GTS300
Guys,
Thank you all for suggestions. Piaggio Customer Support has been very helpful in providing detailed installation instructions. Robot's video, coupled with this, should be sufficient and thorough enough. Here are the instructions attached. I hope I won't get in trouble for posting them.
Edit: for some reason, can't post attachments. PM if anyone interested, will send.
adem_7 wrote:
Guys,
jimc would probably like to stick them on https://manuals.wotmeworry.org.uk/
GTS 300 Super
GTS 300 Super
The instillation wasn't the issue for me, for some reason when I go into Bluetooth pairing it only stays for 10 seconds and goes straight back to the main menu, not sure why but I've given up Crying or Very sad emoticon . Any suggestions?
Vespa GTS300
Vespa GTS300
Siberiangulo yes, had same issue. Apparently, dealer had to provide some software updates to make it work. I sent it there, dealership hooked the diagnostic tool, updated, and now it finally works.
GTS 300 Super
GTS 300 Super
I did some reading and I thought that might've been the case but good to confirm! Thanks
[ Time: 0.0097s ][ Queries: 4 (0.0028s) ][ live ][ 339 ][ ThingOne ]
