@jz54oval avatar
'65 Allstate
@jz54oval avatar
'65 Allstate
Hello all
Ride info
'64 Allstate
150cc
Vape ignition
Sip 2 exhaust
I went to ride my '65 Allstate today and just a block away it came to a quick stop after down shifting at a light. I pushed it in neutral back home. Am not able to push Kickstart lever(it is stuck) if I pull the clutch in I can get the Kickstart to move like normal. Tried to bump start it and it just stops completely. Once I got it home I found that if I turn the flywheel and push the Kickstart at same time it will move but not smoothly(verystiff and sticks). I removed the plug and piston cap and it moves the whole motion but seems to be sticking as it turns. I removed the flywheel and all looks good and have same issue with it off. I pulled clutch in and tried to turn flywheel and it's. Very hard to turn, stiff and sticky. Won't turn easily
Any thoughts on what issue would be or what I need to check next?
Clutch, split case and check crank and bearings?
Thank you for any help or info
@garncarz avatar
@garncarz avatar
Sounds like its could be siezed. Have you pulled the cylinder and have a look at the piston and bore? Pictures too please.
@jz54oval avatar
'65 Allstate
@jz54oval avatar
'65 Allstate
I will do this next
@garncarz avatar
@garncarz avatar
Is there supposed to be a cylinder head gasket?
⚠️ Last edited by garncarz on UTC; edited 1 time
@chandlerman avatar
Innovator
245 Days Since Last Explosion
Innovator
@chandlerman avatar
No sign of a head leak, but sounds like a seize.
There's that interesting bit of wash on the piston crown. Maybe a leak at the base by the transfer?
@safis avatar
@safis avatar
Maybe clutch blew up…
@jz54oval avatar
'65 Allstate
@jz54oval avatar
'65 Allstate
Found my issue. Pulled off the cylinder and found the piston pin is seized to the rod.
Need to figure iut how to get pin out without damaging anything.
@qascooter avatar
@qascooter avatar
A wrist pin puller will help.
https://www.scootermercato.com/Scooter-Parts/Other-Helpful-Tools/12-1026_2
This might do it also
⚠️ Last edited by qascooter on UTC; edited 1 time
@jz54oval avatar
'65 Allstate
@jz54oval avatar
'65 Allstate
Cool thank you
@greasy125 avatar
@greasy125 avatar
if it's OG with the bushing in the rod and not the bearing, you'll want to update that or risk it happening again if you don't do something to correct it.
glad it's thus far and easy fix...
@jz54oval avatar
'65 Allstate
@jz54oval avatar
'65 Allstate
Thank you. Yeah I'm glad it's not to bad. I'll se if it's bushing or bearing. I'm guessing it's bushing as the only thing added was the piston and cylinder to make it the 150cc from 125cc
@qascooter avatar
@qascooter avatar
I did the same thing. Except I went to a penasco two port 177 kit. With a bushing. The bushing didn't last long...
@jz54oval avatar
'65 Allstate
@jz54oval avatar
'65 Allstate
Did you have to change the rod that had a bearing or just change the bushing to bearing on same rod?
@qascooter avatar
@qascooter avatar
I split the cases and put in a new crank that utilized a bearing at the wrist pin. And while I was in there I replaced the bearings and seals, and opened up the rotary pad a bit.
The tale of two rebuilds - VNB2 and VNB5
62 Allstate - getting it back on the road (B62's thread)
[ Time: 0.0108s ][ Queries: 4 (0.0045s) ][ live ][ 343 ][ ThingOne ]
