@tom_gts avatar
Gts300
@tom_gts avatar
Gts300
Hi,
I own a Vespa GTS from 2016 and recently bought a second GTS from 2022 (800miles).
There is noticeably much more play in the ignition lock on the newest Gps. To get the key out (in the off position), you have to move the key it a little left and right to get it in the right position to get the key out. My older GTS does not have this problem, the lock works far better.
It has this problem with both keys
I already removed the glove box panel and inspected the lock and I don't see any damage. Also the keys look fine.
Is this normal operation?
@tom_gts avatar
Gts300
@tom_gts avatar
Gts300
Do you want guess where these parts are sourced from? Honestly, it will probably break in and smooth out over time. You also might try aging the key a bit by rounding off the sides a bit - take a look at the 2016 keys for reference.
@tom_gts avatar
Gts300
@tom_gts avatar
Gts300
It doesn't seem to be a key problem. It turns fine in the lock. But it's harder to get it in the right position where the key can be taken out.
@oldfatguy avatar
Hurricane 200X, 2020 TW 200 (sold), 2022 Liberty 150
@oldfatguy avatar
Key on my 2022 Liberty 150 behaves as described above. IMHO not a big problem. Have not tried it yet but maybe some dry graphite lube would help.
OFG
Try a quick squirt of Tri-flow into the innards to free up the lock.
[ Time: 0.0122s ][ Queries: 3 (0.0022s) ][ live ][ 343 ][ ThingOne ]
