Hi,
I just bought a wonderfully Vespa gts 300 super from 2009 ( M45200). it is in very good condition, the only small issue is that the main front light plastic 'glass' has a little molten spot. I think it's the H4 halogen bulb that produce too much heat. I plan to put a H4 led bulb as it supposed to generate less heat. Is there a Canbus that can be disturbed by a led bulb? Do I need a ' antierror' adaptor or something else? I don't think there's too much electronic on a 2009 model, maybe the anti-thief key code system? Thank for your help, Philippe.
