mp3
mp3
Hi, 1st world problem, purchased an MP3 250cc, with a destroyed ignition switch and no keys, contacted Piaggio, replacement ignition key and lock no longer available for purchase. Is there anyway to disable immobilizer so that I can install a third party switch & key.
2016 Mp3 500ie Sport
Hi GearboxOz
No worries, perfectly legitimate question no matter which part of the world you reside in.
The dealers do not want to maintain anything over 10 years for Piaggio but fi you ask nicely and provide the parts they may help you out.
Parts can be found on EasyParts.com. But you must check the VIN and model for your Mp3 to make sure you are getting the correct parts. While many parts are common across all models, some are surprisingly model unique.
Check this page and see if it has what you are looking for. This is the diagram and parts for the 2010 NAFTA Mp3 250 series but your model may be different.
https://www.easyparts.com/explodedview/Genuine-parts-Piaggio-MP3-250-IE-RL-MIC-E3-2010-(NAFTA)-Switches-m22899-d167783
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
any ignation switch of a Mp3 will work
you only need to re program the ECU to accept new keys transponderchips
there is a tool with software that can read the hex code https://www.immo-tools.lt/en/distributors.htm about 200 euro
find someone who all ready bought it in the US
Find a immo specialist they can read write and make transponderschip to put in the new keys
Buy a used ECU/ throttlebody with transponderchips or with complete ignationswitch with key
https://www.mhrwebshop.nl/pages/bakery/gasklephuis-ecu-piaggio-mp3-250-ie-22538.php
https://www.baboon.eu/nl/onderdeel/piaggio-vespa-mp3-250-ie-rl-2006-2008-m47201-contactslot-set-met-immobiliser-2007/000001130861
⚠️ Last edited by Maksor on UTC; edited 2 times
contact these guys, they should be able to reset the ecu and then make a new key without having the originial keys
https://www.af1racing.com/AF1-RE-VIRGIN-AF1-Racing-Immobilizer-ECU-Service
[ Time: 0.0087s ][ Queries: 3 (0.0016s) ][ live ][ 341 ][ ThingOne ]
