03 Stella 2T TX200
03 Stella 2T TX200
Hi. Looking for photos and info on wiring in a blue ducati cdi directly to a px or 2T stator on my TX200 type ( no ele start. kick start only) engine. Any input or photos would be much appreciated.
w.c.
@bananasplit_00 avatar
PK125XL elestart
PK125XL elestart
I belive i have the Blue Ducati ignition on my PK125 if thats any help, wont have access to take any pictures of it for about another month though as it is locked away for the winter
@mjrally avatar
@mjrally avatar
What CDI was on your Stella?
@scooterist avatar
@scooterist avatar
What stator do you have? The Blue Ducati CDI all have the same wiring except the kill switch wiring. I am running blue Ducati on my LML engine and I have a 5 wire stator because I like its simplicity and it doesn't have the starter.
Need help please with putting a p200e none starter in a LML.
@frank_n_stein avatar
Jet 200, P200E (x2), T5
Not sure I get the question, but in case OP is still interested a few months later, the Ducati CDI has 4 slots from left to right: white / red / green / green. If the issue is non-corresponding wire colors from the stator:
-the ground wire from the stator goes to the white slot on the cdi
-the pickup wire from the stator goes to the red slot on the cdi -the low tension coil wire from the stator goes to the next green slot on the cdi
Whether the stator is a 5 or 7 wire unit, there are only the aforementioned 3 wires going to the cdi.
The fourth skot on the cdi (green) takes the kill wire, and can be switched with the other green.
[ Time: 0.0086s ][ Queries: 3 (0.0025s) ][ live ][ 343 ][ ThingOne ]
