Found another issue with the bike I've had for a month. I rode it this morning and turning out of my neighborhood, the steering seemed off. Like it really didn't want to go the direction I wanted. I've felt this before when the tire pressure was low, but I pulled over and checked and the tires were fine. I got back on and rode some more. The front end seemed to wander a lot and low speed steering is not as responsive as it has been. I guess it's time to check the steering bearings. With this and the fuel pump issue, I'm going to have the whole bike apart.
I think it might actually be the front shock. How easily should it compress when pushing down on the handlebars? It seems to bottom out pretty easily and makes a clunk sound. It also compresses the front some just sitting on the bike.
![]() 2006 Vespa GT (Rocket): 2007 Vespa GT (Vanessa): 2009 Yamaha Zuma 125: 2018 Yamaha Xmax (Big Ugly), 2023 Vespa GTS300 (Ghost)
Posts: 5338 Location: Jacksonville, Florida |
WLeuthold wrote: It sounds to me to be low tire pressure. |
NightWing wrote: What are you running for air, front and rear? |
What are the factory specs? And where did you find them? In the handbook or the metal plate attached to the chassis?
NightWing wrote: What are the factory specs? And where did you find them? In the handbook or the metal plate attached to the chassis? ![]() |
It's not the tire pressure. I've ridden with the pressure at the same level for a month with no issues. When I picked the bike up, the tires were pumped up too high and it still handled fine, it just was noticably harsher over bumps.
![]() 2009 GTS250, Ducati Monster M900, KTM 390 Adventure, Honda CR125
Posts: 1827 Location: Oceanside, CA |
jrstone wrote: I think it might actually be the front shock. How easily should it compress when pushing down on the handlebars? It seems to bottom out pretty easily and makes a clunk sound. It also compresses the front some just sitting on the bike. I have an aftermarket front shock, so I cannot compare apples to apples, but I do not recall it easily bottoming out. |
Shebalba wrote: I think we need to explore this more. This is the stock shock? Are you able to capture the 'bottoming out?' I have an aftermarket front shock, so I cannot compare apples to apples, but I do not recall it easily bottoming out. |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 44794 Location: Pleasant Hill, CA |
I've had to replace the front shock on a 300 before now - and yes, it does upset the feel of the steering.
jrstone wrote: I honestly don't know what's normal, but this seems too easy to push down without a lot of force. How is the alignment and tire balancing? Are the tires original? Did you hit a large pothole? Bonus points for your Vans though. Nice. |
Shebalba wrote: You will get some sag when you sit on the bike, My Malossi front shock actuates fairly easy when I push down on it with some associated clicking and noises. How is the alignment and tire balancing? Are the tires original? Did you hit a large pothole? Bonus points for your Vans though. Nice. |
jimc wrote: I've had to replace the front shock on a 300 before now - and yes, it does upset the feel of the steering. |
Another thing that can really upset steering is the swing-arm bearings. No, not the exhaust support bracket, but the four needle bearings that help keep the front of the engine attached to the frame. Also the 'silent blocks' can produce some vagueness.
Parts no.3 (2 off 600161) and 8 (2 off 597374) : ![]() |
NightWing wrote: Do you have a top case or other container on the back? |
jimc wrote: Another thing that can really upset steering is the swing-arm bearings. No, not the exhaust support bracket, but the four needle bearings that help keep the front of the engine attached to the frame. Also the 'silent blocks' can produce some vagueness. Parts no.3 (2 off 600161) and 8 (2 off 597374) : ![]() ![]() |
That looks pretty average, so doubt that's a problem. There are other silent blocks, in the crankcase, and I sincerely hope yours are OK! See:
GTS 300 crankcase silent block replacement question (solved) |
jimc wrote: That looks pretty average, so doubt that's a problem. There are other silent blocks, in the crankcase, and I sincerely hope yours are OK! See: GTS 300 crankcase silent block replacement question (solved) |
jrstone wrote: Yeah, that doesn't look fun. I'll see if I can get a look at that one in the daylight. Thanks. The way to test is to get a friend to hold the frame securely while you try to move the whole engine and transmission assembly from side to side - any movement at all and those bearings will need inspection. It's possible to change out the needle bearings, but if time is in any way a factor, it makes more sense to replace the whole swing-arm (if that's the problem, that is). |
Small update, but not fixed. I took the handlebar off and checked the top steering bearing. Nothing seemed abnormal there. There doesn't appear to be any binding or notchiness to indicate a lower bearing issue. I'll see if I can take the swingarm off tomorrow and look at the bearings in the rear.
Oh... and I'm a moron. Putting my tools up, I noticed I left off the plastic cap that goes on the bearing. So I get to do it all over again.
jrstone wrote: I'll see if I can take the swingarm off tomorrow and look at the bearings in the rear. I really do wish MV members would stop calling that support bracket 'the swingarm' - it does sweet eff-all to help the engine 'swing', it's bolted rigidly to the engine casing. |
![]() LX190 Friday afternoon special, [s]Primavera[/s], S50, too many pushbikes
Posts: 10939 Location: Hermit Kingdom |
jimc wrote: I really do wish MV members would stop calling that support bracket 'the swingarm' - it does sweet eff-all to help the engine 'swing', it's bolted rigidly to the engine casing. |
jimc wrote: I really do wish MV members would stop calling that support bracket 'the swingarm' - it does sweet eff-all to help the engine 'swing', it's bolted rigidly to the engine casing. GTS Swingarm, Uuuugly It's a much wider used nomenclature than just MV members. Both SIP and Zilioni call there aftermarket support brackets 'swingarms.' SIP also lists the OEM one as the swingarm. https://www.sip-scootershop.com/en/product/swing-arm-piaggio-right-rear_PI019030 We should probably also rename the swingarm puller. I promise to refer to it as the exhaust support bracket from now on, in solidarity with your efforts. |
Dear old SIP also call part of the front suspension 'swingarm' as well as the actual swingarm and the exhaust support bracket. Sigh.
jimc wrote: Just in case of confusion with nomenclature - are you calling the exhaust support bracket (as Piaggio call it) the 'swingarm'? 'Cos it ISN'T the actual swingarm, which is in front of the engine, not in the rear. That's where the usual suspect needle bearings live. I really do wish MV members would stop calling that support bracket 'the swingarm' - it does sweet eff-all to help the engine 'swing', it's bolted rigidly to the engine casing. |
![]() UTC
2019 GTS 300 HPE SuperTech 72,000km
Posts: 7219 Location: Batmania aka Melbourne, Aus |
![]() 2019 GTS 300 HPE SuperTech 72,000km
![]() UTC
GTS300 Super 2023 Beige
Posts: 3457 Location: Sydney, Australia |
I think I am heading in the same direction with my old 2015 facelift GTS300. It is fine on the straights, but as soon as I lean into a corner something doesn't feel right, as if the wheels are not in line.
Can't feel any engine wobble with the bike on the centre stand, and tyre pressures are ok, no loose wheels. So I suspect a faulty shock (Malossi RS24s) or those engine mount bushes. Might put the original shocks back before looking any further, as that is the easiest thing to do. |
Mike Holland wrote: I think I am heading in the same direction with my old 2015 facelift GTS300. It is fine on the straights, but as soon as I lean into a corner something doesn't feel right, as if the wheels are not in line. Can't feel any engine wobble with the bike on the centre stand, and tyre pressures are ok, no loose wheels. So I suspect a faulty shock (Malossi RS24s) or those engine mount bushes. Might put the original shocks back before looking any further, as that is the easiest thing to do. |
I was able to get the new exhaust bracket bearing installed today. Also put the new muffler on while I was at it. I took it for a test ride and it seems like that did the trick. I may go ahead and order the Malossi silent block just to firm things up a little more, but it didn't feel like it had a mind of it's own when turning.
jrstone wrote: I was able to get the new exhaust bracket bearing installed today. Also put the new muffler on while I was at it. I took it for a test ride and it seems like that did the trick. I may go ahead and order the Malossi silent block just to firm things up a little more, but it didn't feel like it had a mind of it's own when turning. Now you need to paint that thing that shall never again be called a swing arm. |
![]() UTC
jrstone wrote: I may go ahead and order the Malossi silent block just to firm things up a little more if looking to firm the bike up you could also/instead replace the bushings at the top of the front + rear shocks (I've done this) |
SteelBytes wrote: the engine swingarm one? if looking to firm the bike up you could also/instead replace the bushings at the top of the front + rear shocks (I've done this) |
