2019 GTS300 HPE SuperTech 66,000km
Both the pads on my front Frando brakes have a chip out of them each about the same size and placement
They've always have a high pitched chatty tinkly sound to them.
17 months, 19,000km. Plenty of meat on them.
Thoughts?
⚠️ Last edited by SteelBytes on UTC; edited 4 times
@breaknwind avatar
Red Devil SH150i (11,000)
@breaknwind avatar
One of the pads on my BV separated from plate after 2,000 miles. Glad it wasn't the front. Life's a gamble.
@waspmike avatar
@waspmike avatar
I'd say you still have over 98.8% of the pad surface available. If you had a drum brake you could fill the dimple with collected brake dust and superglue.
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
Check the disc, if there are grooves on the surface, then possibly something harder got stuck the pad and the disc to cause the chip.
If thats the case depending on the depth of the groove one could grind the disc a bit to smoothen it out and I would replace the pads( they are relatively cheap).
I have to replace pads and discs( possibly) this summer.
Manufacturing defect that showed up later? I would just run it,
baba12 wrote:
Check the disc
it's perfect. (and the same age + distance)
one I've the things I've read is that significant heat can cause this - maybe in combination with the the rust?
[ Time: 0.0110s ][ Queries: 4 (0.0033s) ][ live ][ 328 ][ ThingOne ]
