@stuarttiainen avatar
PX232, Rally 221, GL150
So, picked up this ratty looking '84 PX200 for cheap cheap. Any old Vespa in Australia at the moment is selling for crazy money so was refreshing to grab this barn (shed) find. Patina is perfect, so plan is to keep the paint/bodywork "as is" and do a bit of a mechanical rebuild. Plan is to...
- Rebuild engine with
- new bearings and seals
- new SIP 200 aluminium top end with
- SIP 60mm 125/-5 crank
- SI24/24
- used SITO plus exhaust (wanna keep that ratty look and love the SITO sound)
- replace cables, hoses, etc...
Question is how to set up the barrel, I'll need assistance with the measuring of ports and figuring out of base (or head) gaskets.
I'm keen to polish the inside of the glovebox, haha!!
strange to see this in Australia!!
lifted the seat about about a dozen times then the hinge snapped!!
@hibbert avatar
Vespa
@hibbert avatar
Vespa
Nice specimen
@scooterist avatar
@scooterist avatar
Congrats on the new ride.
@subetherbass avatar
Nice score Stuart.... should be running by Mooloolaba!
I also have Never seen a TaffSpeed sticker in Australia.
Yeah, should be running by then easily. I believe it's got new rings at 35k kms and that's it but no idea why it has that decal on there, old school cool!!
Hope it's more than just a cool sticker
Haha!! I doubt it, but that's where I come in with the subtle rebuild. If that doesn't suffice I always have this...
221MHR build on Malossi cases for a Rally 200 clone that I'm building
Milled out to 100mm, just in case I decide the go big boy crank and 244
That should do it
@zachyzach avatar
@zachyzach avatar
Classy patina on that P series barn find. Good opportunity for polishing her up. Personally I'd try some gentle wire-wheel + brass-brush action on the worst of the rust (glove box?) and then stabilize those spots with phosphoric acid. But the frame's paint will buff out beautifully.
Finally got time to start looking at my rat... engine out, it'll get a rebuild later but looking at a new loom. So this one has a battery but looking at looms on SIP not sure which will be the best one to order. I'm thinking about this one...
https://www.sip-scootershop.com/en/product/wiring-loom-217897_86100000?usrc=Wiring%20Loom
So, deleting battery and going to simple 3 wire regulator and 2 wire stator which I'm just used to. Will it be as straight forward as just changing the loom over and swapping stator and regulator? What about the igniton switch?
engine out!!
engine out!!
On another note, I've bought the SIP 200 aluminium kit but heard not so great things about them... has anyone had experience with them?
Well, the dirt does go with the rat look?
Might pop this in while the 200 is on the rebuild table
@hibbert avatar
Vespa
@hibbert avatar
Vespa
Dang that has a little accumulation. It will be faster just being lighter.
I know right?!! I'm not disappointment, I'm impressed!!
@colinbelgium avatar
VBA1T/Px200 iris/VNB6T
Cool looking Vespa ! I wish I could have found a rat Px200... I bought the most miserable one, rebuilt everything and made it rust, but your is a true one !
That looks cool? Stock running gear? I'm luck to have a few rats... I can't have nice things
1975 Super with 221 rotary setup
1991 PX200 with 232 reed
Nice rats !
Yes my engine is a Px200 stock. I have a Polini 210 (the new one) and an exhaust for it but did not install them yet. When I rebuilt the engine I did put a reinforced cosa clutch but no other mod.
In Belgium you have to pass a tech control in order to register , they are very critical and that is why the engine was rebuilt stock.
@robbie_11 avatar
PX
@robbie_11 avatar
PX
Great Find.
I would love to find something like this.
If it was me i would restore/modify all the running gear, treat any major rust if any and leave the body looking exactly as it is....
Love It.....
Good Luck with everything...
⚠️ Last edited by Robbie 11 on UTC; edited 1 time
It's just getting an engine rebuilt with new stock top end with GS piston, body will stay as is.
so much dirt and grime to clean off!!
major components all clean after a bit of elbow grease
So engine all rebuilt with new everything, standard top end, GS piston, new 24SI carb, old SITO plus that I had on the shelf. I ended up replacing with a new loom from a MY98 vespa as it seemed difficult to get the exact specific model for this scooter. So now the only things that don't work are the warning lights on the dash and the fuel gauge. With no lights on, the high beam and indicator dash lights stay on, when I turn the lights on (either park/low beam) the warning lights go off. When I indicate the warning light only works when the headlights aren't on!! haha!! oh well, I guess I'll have to try n suss that out another day, once I figure out how. I hate wiring.
But, all the lights work and indicators, stop light, so that's a plus.
stock top end, GS piston, stock type mazzuchelli crank
GS exhaust stub
GS exhaust stub
all buttoned up and ready to roll
SITO plus bolted on, gives the right sound for an 80s scoot. Sneaky shot of the rego plate, ready to ride for reals!!
@robbie_11 avatar
PX
@robbie_11 avatar
PX
Looking Good...
Good luck..
[ Time: 0.0219s ][ Queries: 4 (0.0108s) ][ live ][ 334 ][ ThingOne ]
