Hello
I have a PX150, registered 2016, but date on seat is 2014, bought second hand, and brilliantly I've managed to lose both the keys.
Sent off for replacement barrels, and noticed the Piaggio-branded keys also say 'Zadi' and have a 4-digit code.
On the key-ring on which the original keys were on there was a small metal piece with a 4 digit code on it. Having done some research I used the UK firm Key2Code to try and get replacement keys, but none of them worked (usually being too long, but even roughly the correct length were no good).
Having done a little research it seems very likely PX150 of this age will use Zadi keys (and certainly has the Zadi3100 cuff around the lock). I got replacement barrels, and the Zadi replacement certainly slides beautifully into the lock.
My question simply is, can anyone confirm whether this metal tab is what the code for Piaggio/Zadi keys looks like? (before I give up and try and change the barrels myself. Wheel lock is on, which I believe makes things more tricky)
Any advice of anyone who could potentially cut a key from this code other than the firm above, or what is the correct key to request, will be appreciated.
