Hot engine and hot exhaust + water ...
Also since the 'sports' exhaust (arrow) doesn't use gaskets on the mid pipe joins, it would let water in.
![]() UTC
Posts: 7518 Location: Batmania aka Melbourne, Aus |
![]() 2019 GTS 300 HPE SuperTech 73,000km
Also since the 'sports' exhaust (arrow) doesn't use gaskets on the mid pipe joins, it would let water in. |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 45198 Location: Pleasant Hill, CA |
I always reckoned that 'up to the floorboards' was fine, and did that several times, with seemingly no ill effects.
Positive
jimc wrote: I always reckoned that 'up to the floorboards' was fine, and did that several times, with seemingly no ill effects. From: Under An Imaginary Tuscan Sun (Post 953138) ![]() |
![]() S50, R1100s, way too many pushbikes
Posts: 11079 Location: Hermit Kingdom |
![]() UTC
Crossed the one I had planned.
Was deep enough to wet the bottom of the crack case / sump but not much. About 5-6 inches in the deepest bit. ![]() ![]()
Positive
![]() 2013 Vespa GTS300 Super, 2022 Kymco AD550
Posts: 62 Location: Eden Prairie MN |
Motorcross off road with a Vespa. Something is wrong here?
Best to you Dusty Trail Cowboys. As for me, smooth paved roads. Bob Copeland
Positive
![]() 1961 VS5T, 1981 P200E, 2003 Malaguti F12 Phantom,Rigid Frame Chopper, 2001 Harley FXDXT
Posts: 1780 Location: Ventura, CA |
znomit wrote: My advice: Be prepared. ![]()
Positive
eeeee bip
![]() BMW R1100RT The Problem Child Kymco Downtown 300 - I'm not the Uber BMW R1200 RT Big Red
Posts: 21598 Location: South East Great England of Britishland |
![]() UTC
![]() UTC
tinddu wrote: I guess no over the floor board. over the floor would have flooded the battery and regulator etc but splash the bottom of it without getting more than a drop in, sure. PS yes for deeper water could *maybe* rely on creating a bow wave to separate the water making it shallower under the floor. But this would probably only be possible with a good river bottom eg a proper concrete ford with no slime etc. Although then if too fast the front wheel will loose traction and drift down stream ... ouch
Positive
![]() UTC
https://www.instagram.com/reel/C6yYTWbIPhg/?igsh=MzRlODBiNWFlZA==
^^ so near getting electrics under the floor boards wet ... |
![]() 2007 250 GTS, 1980 P200E, 2010 ThunderFly 190 (SOLD) 2015 Yamaha SMax (SOLD)
Posts: 3622 Location: Springboro, OH |
I've done a few water crossings, but max depth was probably 7 inches.
"A little dirt ain't gonna hurt" Here's a video from a group ride in Indiana... Skip to the 2:15 mark if you want. ![]() |
![]() UTC
