Hi, Just got new toy.i have keyless access , but cannot find any location or tag where I can attach Master key to activate passive recognition…cannot see place for master key or for fob.According manual somewhere under seat, but cannot see any place there where I can attach chip from master key … want to be ready for any situations.Thanks for advice .
Can anybody check where on your scooter mp3 400 or 530 2023 model located the place to put your remote in case of low battery or master key to start the scooter???? According manual the place is under seat , but I cannot see any location under seat as on the picture in the manual! Please answer as soon as possible .We all need to know what to do in case of lost remote control or low battery from remote control.
Thanks in advance to all MP3 drivers With 2022-2023 400 or 530 models.
Spend half day to figure out the location.Finally discovered just little bit above 2 screws inside of luggage compartment from left side.
Now at least I am safe to know how to start MP3 by master Key
You can use 2 locations
One as I described in my post from inside of area under seat.
But as described in manual you do not need to open the seat.Just look under seat from outside from left side and do not open the seat!
It clear description in manual and I was looking under seat when open the seat. ssd you can attach your key just from outside , left side .Lookfrom bottom of seat from outside without opening of seat and you will see immobilaizer unit where you attach key near by and push your main switch to on .
All Content Copyright 2005-2024 by Modern Vespa. All Rights Reserved.
