Update: some decent progress making this contraption easier to service (carburetor 🤬) and reasonably reliable to ride more than a few blocks from the shop.
A friendly local gentleman came by told me his Vespa PK50XLS wouldn't start, so we went over to his house where I discovered that the XLS model is apparently the infamous Pluramatic Facepalm emoticon . I think that Piaggio used the poor PK platform as a guinea pig to test out some of their early belt drive schemes and the crude Pluramatic was not much of a success.
Recycle is the easiest & probably most sensible option, sell off any useful stuff & scrap out the rest! But the frame is in really good shape w/ mostly nice paint and IT HAS PAPERS, a pretty big deal here in Greece!
Rebuild is probably out of the question, parts are impossible to find and I doubt it would be worth it if you could find them. Here's the only thread i could find on the topic: Vespa PK50 Plurimatic .
Repower if there's a way becomes the only choice left if we don't wanna lose that precious pedigree... I just happen to have a potential donor PK w/ no papers that would help a lot - motor, headset, gas tank, foot brake for the rear and a general idea of where to cut & weld. IF it's doable, I'm still investigating & need to discuss w/ owner.
my paperless PK
Opinions and advice appreciated!
Nice low mile PK50XLS, but where's the brake pedal?
oh... damn Pluramatic can of worms...
Makes spark, but kicks over kinda slow & weird. Top sheave has some wobble.
Let's have a look, tighten it up if we can. Maybe it didn't wobble much the first couple of miles, but after what I found, I think there's not much more than luck & rust holding the flywheel on its taper.
Nope, can't tighten this! Looks like the splined crankshaft extension that carries that sheave snapped off and some optimistically ambitious soul has already "fixed" it w/ some kinda drive pin!
āš ļø Last edited by V oodoo on UTC; edited 3 times
@safis avatar
@safis avatar
I fixed that for you… ROFL emoticon ROFL emoticon ROFL emoticon
Problematic Pluramatic Problematic PK - recycle, rebuild or repower?
They didn't get the name for no reason. Parts are hard to find and expensive. There's a chance you'll find something on car.gr or FB Marketplace…
@safis avatar
@safis avatar
@norman avatar
1978 MotoVespa 160GT, 2009 LML Star 2T (Stella), 1961 Lambretta S2
@norman avatar
I've got nothing constructive to add, but get me some of that Hellenic slop!
Norman, yours for the Special Sale price this month of only 450€ ! (shipping not included)
@norman avatar
@norman avatar
I'm tempted, but what is it?
@mor avatar
1974 v90, 1959 Allstate, 1979 p200
@mor avatar
What's the headset like? Easily converted to shifty?
Repower if possible. It will be a good challenge to make it work. Take what ever is left over from the original and recycle that.
@safis avatar
@safis avatar
It's not only the headset. Frame is totally different, can't accommodate a shifty engine and there's no foot brake…
I know that I'd need to reshape the engine and gas tank cavities, and add a foot brake too. Cutting and welding to do and I still ain't too scared yet.
But first I need to talk to the owner and see if we could deal, either do it for him for too much money or maybe buy it cheap enuff to get me interested. I should know more tomorrow.
It's still a roll of the dice if I could pull it off, but take a look at the effort Whodatschrome went to putting a P200 motor in a PK! PK Smallframe with a P200 engine?
I could use my plastic headset or get an older half metal 4 speed similar to what it has now, that one won't work. This seems easier than stuffing in a P200 motor in some ways, the pivot & shock mount positions seem the same(I'd wanna pull problematic motor to verify) and I would have my old PK to copy internal sheet metal and get all needed parts from.
I have pro mig & tig welding available after I fit & tack in any needed panels.
The tank cavity has a huge hump but it's covered w/ insulation and you can't tell the depth so I laid my glossy old Scooter Works catalog on it so you can see how shallow the clearance is. Look at that long skinny tank!
Here's my PK tank & tool tub, they fit perfectly but need to go down a few inches most places, more where the fuel tap is.
Here's usual PK tank cavity, notice how small the motor bulge compared to the other. And a carb cavity would need to be added.
The description is in the older Pluramatic link I posted. The shipping would kill you! Crying or Very sad emoticon
The inspection & feasibility survey continues, checking to see what it would take to use existing headset. Looks maybe šŸ¤” possible.
Hoping to meet w/ owner tonite or tomorrow and make a plan.
Headset greetings from Pluramatic cooties!
@mor avatar
@mor avatar
Wow, its got a shift cable ring in there! you're half way done Laughing emoticon
Right you are! It is apparently used to go from Neutral (0) to Drive (1).
You'll notice that it has a dot for auto and also a dot for a shifty further up in the normal place but the casting is pressed or glued into the base, you can't twist it - only the grip. That may change...
Well OK, I'll give it a shot!
I swapped my beat up paperless Cosa for it. It runs mostly reliably and everything worked today - lights, turns, horn and it fired right up. I'd forgotten how smooth it is, buttery clutch & hydraulic brakes but what a heavy handful for me now. I rode it all over Athens & beyond for maybe four years when I first started chasing cheap old Vespas to rescue...
Anyway I did love that beast but it was looking for a better home and found it today w/ happy new owner.
So I now own a legit PluramatiƧ and have begun its transformation. Still lots to do and more to figure out.
This side looks OK
This side looks OK
This side too and it bolted right in, even using the original pivot bolt & shock
This motor is a mock-up w/ old tired parts but that is a 90cc top end. Enough room in there to raise a small family
Intake even fits but gonna have to relocate that wall
Other side of the wall from the top - rather narrow currently
So yeah, I traded this beast
for this little beauty
(engine mount adapter in foreground)
for this little beauty ... (engine mount adapter in foreground)
If anyone can figure this out, it will be you, Terry. Good man for taking this on.
@hibbert avatar
Vespa
@hibbert avatar
Vespa
I was thinking the same but I also thought voodoo might come up with a solution on the pluramatic engine. I like the direction it's going.
@mor avatar
@mor avatar
Plurfect!
I'm on a PK binge! It's going well, I got the foot brake fitted and brake cable run. Now just wire up the brake lite switch.
The headset has a few problems, but I think I can convert the original to work. Extra challenge - If I can I wanna use the single cable shift system I love too much from my donor XL2, but I may have a plan...
So mostly should work after I figure out a headset and weld in an air box for the carb. I'll use the original gas tank w/ a hinge at the back for carb access. I want to disturb the monocoque frame as little as possible, plus imagine the huge exhaust I could put in that space!
Laying out brake hole positions, copying XL2
And the base fits, now cut the pedal hole.
I drilled the corners and cut shallow because wiring & cables inside big hole.
And the base fits, now cut the pedal hole. I drilled the corners and cut shallow because wiring & cables inside big hole.
Original mat has pattern for foot brake, but no hole
Donor, thank you for your faithful albeit illegitimate service, but you shall live on with an older body and new credentials
The brake was easy compared to fitting the motor, the intake & carb being the obvious problem. Everything else simply bolts in. To form a place under the seat separate from the motor using mostly the original sheet metal and making it structural is the biggest challenge.
It might seem more sensible to cut out its innards and swap from donor bike which we considered, but my friend Kostas who knows more about these things than me(pro welder, machinist & race bike tuner) admitted it would take a lot more time, so we are gonna try my sheet metal surgery conversion, which he will weld up.
Marking the cut to fold the existing piece back vertical, bike is laying on its side, floor on the left. The cut on the left(bottom) is just past a seam that will be welded to.
I bent the cut piece vertical to floorboard and also cut along the top arc leaving a 1/4" ledge to weld to. I started bending the top 'dome' down to meet the cut piece
Starting to look like a carb can fit, but lots of bending and forming to do to get the manifold in there too.
We will need to add a crescent shaped piece like the cardboard template to close the hole on the side of the new carb compartment
Here's a better view, the yellow tape is on a temporary 'ear' that is tack welded holding top & bottom together and will be cut off once crescent is welded in place
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
you're really going for it now, I applaud your courage
Go, Terry, go. Good man.
Thanks guys, I almost wish there were more dead Pluramatics laying around, and all this stuff could be put to wider use, but if this all works I will likely have the only such conversion around.
Motor installed, carb on manifold and in its new place
Carb from above, must bump in some clearance for carb clamp screw and throttle cable mount after final welding
And here's where the skilled welder w/ the best wire feed equipment comes in. The two pieces meet just above the red line and the yellow areas get a crescent šŸŒ™ and small triangular patch welded in. Notice the edges of the new 'wall' are bent out
... to form a flange the crescent will be welded to for more stiffness.
The old carb intake hole was in almost the right position, almost like they knew I was coming. Just needed to extend it up a little to pivot the manifold in
... to form a flange the crescent will be welded to for more stiffness. The old carb intake hole was in almost the right position, almost like they knew I was coming. Just needed to extend it up a little to pivot the manifold in
For reference, here's where we started
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
I'm loving this.
Thanks John, but seems not as many Pluramatic fans as for the REAL PKs Crying or Very sad emoticon . Me sort of included since I got my new PK125XL about the same time I fell into this mess. In fact I was shopping Pluramatic parts following Safis' tip when I stumbled on my now perfect ride, light enough and fast enough for me.
But sucked in I was, because a 2nd legal PK is not a bad thing and I'm enjoying the challenge. We just had Welding Weekend as my pal Kosta showed off his fabricating skills. I'm now finishing up the headset conversion w/ fingers crossed.
We used this fitted crescent pattern to start, but needs a shallow cone so I stretched the end points to flatten the curve but same chord length
Kostas cutting crescent
some English wheel action after bashing some dents into it against a bag of sand
planishing to help form dome
hammering the edge back to a flat plane before visiting edge shrinker & stretcher to get our desired shape
lots of test fitting, trimming and bending then finally welding begins with first joining front wall to top dome
next up the magic crescent to close off carb department. I drilled holes for lots of plug welds first between the visegrips, then edge welded at the new wall and dozens of small tacks along the arc to avoid deforming frame or damaging paint
here's welded crescent from inside. Carb just fits after cutting clamp 'horns' off carb & prying in a small clearance dent for throttle cable fitting
close up of all the welding
lots of room for the little 70cc motor, but I wanted  to be sure it would take a 125cc too
finished up the engine bay with seam sealer to keep water out of the seams & joints, then zinc coating for corrosion protection which I'll clearcoat for durability & ease of cleaning
@mor avatar
@mor avatar
Lots of room in there! Still planning to keep the special gas tank?
Yes, gonna use original skinny tank because it's the easiest solution. Plus it has nifty tap handle you just pull and it snaps out , direct connected to the tap which is close to the front(no long rod to annoy me).Very convenient for carb access now.
I want to belatedly thank and bow down to the serious fabricators here like whodatschrome, Safis, Charlieman, Roland and many more who gave me ideas and proper techniques to tackle such a seemingly hopeless project. But with that and having legit papers the bike is being transformed, and I hope to at least test ride it before May 10 when I head home.
@hibbert avatar
Vespa
@hibbert avatar
Vespa
Wow V oodoo you definitely DO amazed at your vision to see this come to fruition. If only the recent T5 posted by tomasvfs was in your hands could see another viable scoot return to service in short order. Respect for what many might consider impossible possible.
Latest pics, it's coming right along:
Rear brake works, I had to cut 2" from cable outer to avoid a big bow
Dang it, I tried to post FOUR pics!
āš ļø Last edited by V oodoo on UTC; edited 2 times
Oops, duplicate post
āš ļø Last edited by V oodoo on UTC; edited 1 time
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
that sounds like a ham bet....
Or maybe a SOUVLAKI bet?
I dunno why I had problems posting pics from my phone, but here's the rest from my laptop
Normal PK tank still 2" too tall even w/ clearance for tap.
With fashionably slim Pluramatic tank, same fork and older horncast installed.
Check out the choke, it's just like a largeframe and works fine here.
Engine in and I'm running and test fitting cables. I like that the electrics are literally plug & play, look just above the black bracket! Those 2 unused black & gray outers are old shift cables to choose Neutral or Drive. I'll use one to pull the fat new shift cable outer, the other to pull clutch.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
mmmm souvlaki bet.....
Mmm right ... If you're laying down a marker in hopes of me getting you souvlaki, you may have it backwards old friend, we should know for sure soon. I ran into a couple of surprise problems and got tied up fixing them today or I may have been out test riding.
First the throttle cable is not happy at the carb because it must come up from the bottom almost under the carb. That meant a 270° loop over the carb, but had to be small enough to still fit gas tank. Just didn't work, too much bind, and time wasted on a losing battle.
So I modified the carb linkage to open pulling straight down on the same side the cable comes in under the carb. Throttle feel is now smooth w/ no bends at all other than a big loop from headset to bottom of new carb enclosure.
Carb works fine now, but why my muffler no fit? Livid emoticon
Muffler came from here
Back to cutting & welding, this time minor and me stick welding it. I'll need to seamseal and poprivet a patch over the triangular hole. No welding, cables & wires behind
Good clearance all around. I taped over the hole for now.
I had another bell crank from a junk 16 carb which I cut & bent 90° to pull down instead of from the left.
Ugly stick welded the tiny pieces
Then a bracket to catch cable outer and a nice 270° improvement. Or just 90° ?
Muffler cavity before enlargement of about an inch, up to the reinforcing rib like donor bike
Looks like maybe you owe me a souvlaki! Just before I left town for Easter week, I took a first run down our block and back. But in a few days I'll give you a rolling shot to collect, IF my luck holds.
Motor was happy after leaving donor bike, both brakes work as they should and best part is the single cable shifter worked nicely - I went thru all four gears!
I still have much to assemble but I have THREE whole days before I leave Greece so I should be able to have it mostly together again.
Foam pad seat and 40ml syringe body 'fuel tank'. I'll use the original tank & seat as soon as I don't need easy carb access and figure out how to hinge the tank.
Single cable shift worked great, that small arm from donor pushes and pulls the stiff wire straight up and down. I drilled & dremelled the new cable passage down thru the headset, locked it in w/ a setscrew.
I first had to cut clutch perch from that pressed in tube after pressing it out. I set screwed it to the rotating tube and Kostas turned up a little adapter for the actuating arm.
Here's a nice group shot on my way out of town just before we loaded the brown one.
Oh, here's the other end of single cable shift. The 'batwing' just has a single hole that the trunnion w/ setscrew Allen wrench hanging out fits into.
Put tranny in neutral and same for grip handle, tighten setscrew and done. Get ready to enjoy click click click shifting, no two flimsy cable tug of war or stretched cables here!
The black shift cable outer is already in place, trapped by a circlip thru that place you'd usually find two cable adjusters.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
IOU one souvlaki
(*souvlaki must be collected in San Diego)
Laughing emoticon
@az_slynch avatar
@az_slynch avatar
sdjohn wrote:
IOU one souvlaki
(*souvlaki must be collected in San Diego at ROM 2025.)
Laughing emoticon
FTFY. Razz emoticon
Hey! I get a say in setting the rules TOO!
ROM sounds good, and how about alternatively the big Athens rally next year? You'd love it John, and Greek souvlaki is the REAL thing! And I'd just assumed we were talking authentic souvlaki...
300+ scooters winding thru town
[ Time: 0.0134s ][ Queries: 4 (0.0049s) ][ live ][ 343 ][ ThingOne ]
