@romax avatar
GTV 300
@romax avatar
GTV 300
So i'm enjoying the break-in km's this week on my GTV 300.
One thing ive noticed, although this can be normal in stop & go traffic, the cooling fan is working overhours.
Today it was a friendly beginning April 23c/73f, so what about deep into hot heated august?
Any hot riders here with experience?
@jkj-fz6 avatar
@jkj-fz6 avatar
Have you checked the coolant level? It may be low.
@romax avatar
GTV 300
@romax avatar
GTV 300
Newly filled up, all well there thank you.
It might be nothing and all feels normal but im just a bit curious about those Hot summer days up ahead.
@wbdvt avatar
@wbdvt avatar
Newly filled up? was it thoroughly bled of all air?
2019 GTS 300 HPE w Malossi
romax wrote:
Newly filled up
ah ...
a) was it low and needed a top up which would suggest a leak (eg loose hose clamp)
OR
b) did you drain and fill the whole system and hence bleeding is important and may need rebleeding
@romax avatar
GTV 300
@romax avatar
GTV 300
Sorry for my English
Its brand new and i checked and saw the cooling liquid sitting on the right level.
⚠️ Last edited by romax on UTC; edited 1 time
@romax avatar
GTV 300
@romax avatar
GTV 300
SteelBytes wrote:
ah ...
OR
Neither a or b, but ill double check the bleeding.
It came new out of the garage with the cooling liquid tank filled as it should be, i saw it when i got it.
I'll check tomorrow if there is a unusual drop, just to be sure.
So i guess the cooling fan doing some work in stop & go traffic with these temperatures isn't as normal.
@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
@dariusz avatar
From my experience, a new engine, while it is adjusted correctly (break-in), always runs a little hotter than when it finishes break-in.
But, it is still not a bad idea to check if the cooling system was properly purged, since I have read some comments about Piaggios that leave the dealership without being properly purged and that air can help cause the temperature to not be correct. So if is mine scooter, I go to the dealer and ask to purge the coolant system... only to be sure all is correct.
[ Time: 0.0105s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
