@roland87 avatar
@roland87 avatar
My mate gave me PK for engine mounts and steering bearings change and some other works.
I changed engine mounts and threw engine back.
And noticed that ignition lock not working. There still a spark on the plug when lock is turn to "OFF".
Ignition is Vape Road, almost new, only 2000 km done.
If I add ground wire between engine and chassis - all works as it should.
The same problem is on my 50 Special with same ignition. But it appeared after near 10000 km and few years since ignition was installed. And also after engine was took from the chassis for rebuild.
I also noticed that SIP sell ground wire for Vape ignition so maybe this is well known problem now?
parallelogramerist
parallelogramerist
I can only assume that it's a problem, what i can't say is if it's a well know problem. Seems like having a CDI that's mounted through rubber bushings is going to be potential for a possible failure. Poor grounding is ALWAYS going to be an issue with anything electrical. For all of my scooter builds i will add in a few extra grounds, one from the CDI to the engine block, another from the block to the frame, and another from the headset to the frame. I usually tack weld the head of a M60x20mm screw to the frame so that it can be a grounding lug (both at the front and rear of the frame.
@bajarob avatar
@bajarob avatar
Roland I second whodat. Rubber mounted engines need a dedicated ground to the frame. Even rigid engines need a metal to metal contact to work correctly. On all the engines in the planes I work on we make sure there are two separate grounding points for redundancy.
Rob
@roland87 avatar
@roland87 avatar
I'm absolutely understand you guys.
But all was work for some time on both scooters without any extra wires...
@safis avatar
@safis avatar
Agree with the gents above. Some extra ground points are a good thing. First pic CDI is double grounded to engine and second pic engine grounded to regulator / frame / battery...
@108 avatar
V range 50s
@108 avatar
V range 50s
It definitely works with the brown cable from the vape stator.
But I think it might not be enough.
Vezzola CDI mounting kits come with a dedicated ground. I've never brought one, but seems like a great idea.
I've added a ground, pretty much what the SIP cable is… 13awg if I remember right.
I'm not sure if a ground from the frame to the engine matters… never seen that before on a Vespa.
@ginch avatar
@ginch avatar
In the past few months I've seen people mention issues - like poor running, spluttering - that cleared up once an earth wire was fitted.
parallelogramerist
parallelogramerist
Here are pics of the multiple grounds on my blue Allstate 12DC vape harness. I'd like to think i'm well grounded.
Battery negative post to frame ground. The m6 screw is welded to the frame.
regulator rectifier is directly bolted to the aluminum battery box which is also grounded to frame. Then a second brown colored ground wire goes from reg/rec and battery tray to the negative battery post.
Brown ground wire goes from the CDI to the engine case.
Another brown ground wire is attached to the other side of the CDI bracket (just in case the rubber mounting buffers do too good of a job as a rubber buffer).
Another m6 grounding lug screw that's been welded to the steering column (right behind the horn).
@bajarob avatar
@bajarob avatar
Just like my mother would yell " You're grounded, Mister!! ".
[ Time: 0.0088s ][ Queries: 4 (0.0024s) ][ live ][ 343 ][ ThingOne ]
