@chatis avatar
1963 Vespa VBB, 1965 Allstate Cruisaire, 1974 Vespa Super, 1980 Vespa P200, 2003 Stella 2T, 2008 Steall 2T, 2022 Royal Alloy 150 GT
@chatis avatar
What could be causing this? Any ideas? Rear hub? Clutch breather?
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
sure looks like your hub seal to me, need to get that hub off and have a look.
your brakes will go to shit if they haven't already.
parallelogramerist
parallelogramerist
I bet it's residual oil from Ned's sidecar clutch cover vent leak. Were you riding directly behind him at ROM?
Also, the rear brake cable clamp looks a bit concerning to me...
@charlieman22 avatar
Nedminder
Nedminder
Hard chuckle.
Maybe.
Chatis - it's one of two issues.
1. Rear main shaft/axle seal.
2. Breather on top of clutch cover
a bore scope can be snaked up on top of the motor to se if it's the breather - but assuming u don't have one - next best thing is probably to pull the wheel off and do a visual inspection.
You will find a trail from where ever it's coming from.
Don't forget the cotter pin…
@scooterist avatar
@scooterist avatar
I have/had the same problem. In one of the engine I had a bad clutch cover seal. on the other one I haven't touched it yet but it is annoying. I also laid down my scooters many times recently swapping cylinder kits and exhaust for testing, I wouldn't be surprise if I cause some of the issues. Also, some exhaust leaks more than others, I found the undercarriage greasy and all the saturated oil from the exhaust typically drips to the very bottom and concentrate.
[ Time: 0.0115s ][ Queries: 4 (0.0051s) ][ live ][ 343 ][ ThingOne ]
