2007 Vespa Granturisimo 200, 2023 GTS 300 HPE
Can you adjust moving the mirrors only? If not are both are sides clockwise?
310 GTV Officina 8
310 GTV Officina 8
No both mirrors are handed. The simple way to remember is if you push them away from the bars, that unscrews them👍. So the left hand mirror loosens clockwise , the right hand mirror loosens anti clockwise.
Guess the logic is " the wind" tightens up the mirror.
On a separate note does anyone know how to tighten up the head of the mirror eg where it connects to the stalk with what looks like a swivel joint, reason being one of mine is loose and the mirror head " droops"
Thanks in advance
@mike_holland avatar
GTS300 Super 2023 Beige
No, the logic is in a head-on accident the mirror doesn't break and pierce your ribcage.
@tor2ga avatar
@tor2ga avatar
There are threads on MV about getting into the mirror head for various reasons. Basically you pry out the rubber ring holding the mirror glass in and remove the glass. It will be obvious how to tighten the joint. Reverse the process to reassemble. I've never done it. It's apparently hard to get back together.
310 GTV Officina 8
310 GTV Officina 8
Thanks Tor2ga , my bikes only five weeks old so Ill mention it at the first service👍
2019 GTS 300 HPE w Malossi
this happened to me after using a bit of wd-40 with a quick wiggle
that method works with older gts mirrors but my mirrors on the HPE don't have this black ring. I only way I see of getting the mirror out would to be use a suction cup and pull. tried that and gave up
what I did was *neatly* put some black tape around the swivel - a few times around. works well and actually looks fine. will take a pic for you later
[ Time: 0.0082s ][ Queries: 4 (0.0021s) ][ live ][ 343 ][ ThingOne ]
