@that1gtl avatar
Vespa GT 125 L
@that1gtl avatar
Vespa GT 125 L
Hello all I need a bit of help to point me in the right direction I've got a 2005 GT125L and I've ran into some trouble the bike will not go over 55mph no matter what I do to it it hits a limiter at 55
It's not an engine fault as ive swapped one over and it's still the same thing rollers been changed to heavier ones no difference the only two things I can believe it to be is maybe the ecu/immobiliser unit has went bad and has changed the rev limiter or can this be caused by a Leo vince exhaust with no baffle any help would be much appreciated. Thank you
Enjoy a picture :)
Enjoy a picture :)
⚠️ Last edited by That1GTL on UTC; edited 1 time
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
2008 will be a gts not gt ..gt is carburettor gts is fuel injection, double check what it is
@that1gtl avatar
Vespa GT 125 L
@that1gtl avatar
Vespa GT 125 L
Sorry it's a 2005 not at home atm so it's of the top of my head
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
Lol no worries..just check throttle cable, spark plug, the usual things 1st..
I don't think the exhaust will affect it ,as they only make more noise lol
I don't think our ecu is as sophisticated as the gts one, anyone locally you could borrow quick just to see if that's the problem m8
@that1gtl avatar
Vespa GT 125 L
@that1gtl avatar
Vespa GT 125 L
I will try have a look but I doubt it and with throttle cable and spark plug it's all good, could it running rich affect it?
@oldschooot avatar
@oldschooot avatar
What was previous top speed?
@that1gtl avatar
Vespa GT 125 L
@that1gtl avatar
Vespa GT 125 L
Somewhere around 65 on clocks
@that1gtl avatar
Vespa GT 125 L
@that1gtl avatar
Vespa GT 125 L
Back from holiday have fitted the new cdi on the first run it ran great got over 60 but ran out of space I then parked up to celebrate went back out 5 mins later pin the throttle it accelerated for about 20-30 seconds and started to engine break I then blipped the throttle couple times and kept it at 1/4 throttle seemed to run fine
Figured out that if I blip the throttle and keep it at 1/4 for a min I can then pin it for about 20-30 seconds before again it starts to bog down
Don't wanna take it to the mechanic yet as I already know their gonna charge a fortune to diagnose and fix it hoping it's something simple as a carb clean spark plug or fuel filter
Any help please
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Try a stock exhaust. I used to have the same bike and I put that same exhaust on it and it made the bike worse.
I think the GT125L really needs the back pressure from a stock exhaust to work well.
Did it start when you put in the heavier rollers? Rollers that are too heavy will kill acceleration and top speed.
@waspmike avatar
@waspmike avatar
At what RPM? Just asking.
@waspmike avatar
@waspmike avatar
It's been a few days. Stick it on the centre stand and see how fast it will theoretically go. Don't aim it at the neighbors!
@waspmike avatar
@waspmike avatar
Yes.
[ Time: 0.0104s ][ Queries: 4 (0.0039s) ][ live ][ 343 ][ ThingOne ]
