@wseobg avatar
Piaggio MP3 Yourban
@wseobg avatar
Piaggio MP3 Yourban
The thermometer does not work. It says minus 17 degrees, then -16, -15 and so on. Ideas?
2015 MP3 500 ie Business
Maybe heat from the radiator influencing the sensor???
@dariusz avatar
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
@dariusz avatar
I assume it is the ambient temperature sensor, correct? +17 and after that change directly to -16 etc? for me sounds as the temp sensor is out and a new one solve this crazy readings
OP said -17, -16, -15, etc.
2016 Mp3 500ie Sport
You guys use the thermometer on the Mp3 as a useful feature?
I suppose its reasonable to expect it should work reliably but I just always expect them to be off by about 10 degrees. I use my phone weather app for accurate weather and the rest is just "do I feel hot or cold".
I think its the "Piaggio Room Temperature Sensor". If the YourBan is anything like the 2016 Mp3 500 I have then the sensor is mounted under the handlebar plastic.
Parts Diagram for 2018 Yourban 300. Make sure to go through the catalog for your exact model-year and version to get the exact right part.
https://www.easyparts.nl/explodedview/Genuine-parts-Piaggio-MP3-300-IE-LT-Yourban-E4-2017-2018-(EMEA)-Electric-wiring-m26973-d200411
Link to the part "Piaggio Room Temperature Sensor".
https://www.easyparts.nl/Room-Temperature-Sensor-p33532443
Alternative brand and solution (check before buying)
https://www.easyparts.nl/Climate-Temperature-sensor-RMS-Piaggio-Vespa-E3-p33532444
Now if your talking about the thermostats and sensors for the engine, radiator, etc then thats a different story and it definitely should be reliable.
https://www.easyparts.nl/Thermostats-and-sensors-c21305682/Piaggio/MP3
@dariusz avatar
@dariusz avatar
You are right, if is not a very very cold day I think the temp sensor is out
And if it's a very cold day, it makes sense that the temperature will increase as the engine transfers some indirect heat to the sensor, right?
My ambient temp sensors in general are plus 3 to 5 C out, but I think is a problem about the place where are, is very easy that the hot from the road foul the sensor.
I use it some times only to say "is more hot that I feel" ha ha ha
[ Time: 0.0092s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
