Looking for thoughts from the crowd on routing a brake line from a handlebar mounted master cylinder, through the headset, and down the column on a VBB.
I want to do a custom stainless hose, but I'm trying to wrap my head around the bends needed inside the headset to get around the throttle lever, headlight, and speedo. I'm using a SIP electronic speedo, so at least I don't have the original speedo cable to work around. I plan on routing straight into the right-side of the headset between the throttle lever and the headlight, so the hose would have to take a 90 degree bend back to the column and then 90 degrees down it.
My new thought is to mount a rigid line from the cylinder into the headset and with the bend to the mouth of the column, where I can connect to the braided steel line for the rest of the journey down.
Anyone see drawbacks to this, or would it make more sense to just do end-to-end braided line and deal with the twists bends inside the headset? I can see both working, but maybe someone's worked through this before.
