How am I supposed to remove this screw from the coolant expansion tank?
Do I actually have to grind a t30 bit down so it's short enough to fit in there? I can't get anything to fit between the screw and the ignition switch. Only thing I can see is the grind a t30 bit down short enough that I can get it in there.
