Hi guys I need advice with setting my carb up on my Vespa p200e none autolube please. The card is a standard 24/24e and the engine is standard with a sito exhaust
You should be at 55-160/BE3/116 stock and with the Sito plus I would say a 120 -122 Main jet, No more than 125 main jet in my opinion and I ran that set-up for a while too.
⚠️ Last edited by scooterist on UTC; edited 1 time
AC160/BE3/125MJ
55/160 idle
1000' elevation
40~100 F outside temps
This is what i put in all my 55mph+ highway cruising stock cylinder (no additional porting) P200's with a Sito+, 24/24E auto lube carbs that get flow matched to both the carb box and case, and the heart drilled out on the air filter. I think most other use a smaller main jet, but i have mine richer so i can hold my throttle WOT at 65-70mph for 20-30 miles at a time with no concerns of seizure.
I got a 120 in at the moment I'm not sure but I think the rest is standard. I'm going to have a look today and change the main just because there isn't much power in 4 gear.
