Vespa GTS 300 HPE Notte 2020
Hi, thought I'd share my GTS HPE pulsing red water temperature findings, finally noticed that when I touched the ECU connection plug it started flashing normally, cleaned both male and female connections and it fitted and sealed correctly, if they don't make a tight seal they pull up all sorts of fault codes. Hopefully it saves someone from buying a new ECU 😵‍💫
I split this off from a very, very old topic, since this post was entirely unrelated.
[ Time: 0.0113s ][ Queries: 4 (0.0053s) ][ live ][ 343 ][ ThingOne ]
