@garncarz avatar
@garncarz avatar
I am getting a clunk when I go over potholes with my large frame. Thinking its an improperly adjusted steering ring nut. Is there a way to check/tighten without detaching all of the cables? TIA.
@jedihunter avatar
@jedihunter avatar
If you remove the headset bolt, and push the speedo cable up into the fork, from the bottom,you should be able to gently pull the headset off the fork enough the tighten the steering ring nut.
@garncarz avatar
@garncarz avatar
Cool. Ill take a swing at it. Thanks.
@qascooter avatar
@qascooter avatar
Yeah, I was going to mention the same thing. I dropped the fork without removing the clutch cable. You can see it in this topic: 62 Allstate - getting it back on the road (B62's thread) (Post 2383390)
[ Time: 0.0128s ][ Queries: 3 (0.0035s) ][ live ][ 343 ][ ThingOne ]
