@chipshot avatar
2014 BV 350
@chipshot avatar
2014 BV 350
Has anyone changed out a check valve?
Want to know what is involved.
Believe I need to do so on the BV350, but find no info anywhere on such a procedure.
First start of the day is always sluggish. Had the fuel injector cleaned, hoping that would solve it, but no (injector didn't need cleaning as it turned out).
Guy who did the cleaning said it sounds like the check valve isn't functioning properly.
@wbdvt avatar
@wbdvt avatar
What's the mileage on it? Is there a check valve in the fuel line? Not sure there is one but if there is it would show on a parts list.
If sluggish during starting, it could be the exhaust valves need to be adjusted.
@jkj-fz6 avatar
@jkj-fz6 avatar
My BV350 always turned over a little slowly on its first starts of the day. I just reckoned the starter was a bit too small for the engine. Be sure your battery is in good shape.
The new BV400 too growls a bit then it's started.
@chipshot avatar
2014 BV 350
@chipshot avatar
2014 BV 350
13,000 miles. Not sure if there's a check valve in the fuel line, figured there was.
It's always been slow to start since I got it (660 miles). Battery is strong. Could the valves get out of adjustment in the first 600 miles?
@jkj-fz6 avatar
@jkj-fz6 avatar
Not likely. The BV350 uses shims instead of locknuts, but at 13,000 miles it's about due for a valve clearance check.
@abner_bjorn avatar
@abner_bjorn avatar
Not an accurate statement. Piaggio is confident of their shimmed valves. First check at 40,000 km or 24,800 miles.
Bottom row, BV350 owner's manual
@jkj-fz6 avatar
@jkj-fz6 avatar
My mistake. It's not due for another 12,000 miles.
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
What do you mean with "a check valve"?
You refer to this guy saying "the check valve is not functioning properly". What valve?
@chipshot avatar
2014 BV 350
@chipshot avatar
2014 BV 350
Believe it's a part that regulates fuel line pressure/prevents backflow?
I never heard anyone mention a check valve on a piaggio scooter. possibly they meant checking the valve clearance?
Do you have the evap crap in OZ? Because there is a roll-over valve between the tank vent nipple and the charcoal canister in places where the evap crap is installed. This could well be described as a 'check valve':
https://www.scooterwest.com/valve-for-canister-cm028201-576461.html
Evap crap, no. A rollover valve, yes (but it's different to the one you linked). But I wouldn't have called that a check valve myself and haven't heard anyone else do so.
You can 'check' something by stopping it. e.g.: "efforts were made to check the disease" (example pinched straight from google).
So a stop valve if you will... "Volet" in Italian?
2008 Vespa S150
2008 Vespa S150
I have a fuel line check valve inline between the output of the petcock and the fuel pump on my vespa. I suspect it could be causing fuel line flow restriction at higher flow rates so I am evaluating bypassing this to see if thats the problem or if my main carb jet is clogged. But for anyone stumbing on this topic fuel line check valves exists on some models. They are red and black plastic.[/img]
2006 BV250, 2007 BV250
My carb equipped 2006 and 2007 BV250's have a check valve in the line between the fuel pump and the carb, so fuel won't drain back to the tank when the bike is parked. These older machines (with a carb) have a vacuum operated fuel pump and it would take a while to refill the fuel line all the way to the float bowl.
I have no idea if fuel injected bikes have a check valve.
[ Time: 0.0298s ][ Queries: 4 (0.0192s) ][ live ][ 343 ][ ThingOne ]
