@mitleider avatar
2024 GTV & 2024 GTS Supertech
@mitleider avatar
Dear friends, we have two new 2024 GTS with "keyless" ignition.
Turning the rotary switch to the on position is very sticky/tricky/frustrating. Can anyone provide some advice, please, about how to manipulate this easily?
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
Please describe your procedure (and what exactly you are having problems with).
@mitleider avatar
@mitleider avatar
With the key fob in my pocket when attempting to turn the switch clockwise to right the rotary simply refuses to move Repeating the procedure two or three times tends to work allowing to inutile starting via the starter button on right handlebar
@mike_holland avatar
GTS300 Super 2023 Beige
I also battle with this stupid switch. I usually press it once before turning it, but sometimes I have to turn it slightly to the left before it will work.
Vespa GTS 300
Vespa GTS 300
Do you press the button before you try to turn it?
@mitleider avatar
@mitleider avatar
No I only press starter button when rotary has finally turned to right to On position
Vespa GTS 300
Vespa GTS 300
I'm talking about the ignition switch! First press, then turn to "on", then start button+brake.
@wleuthold avatar
Wanted
Wanted
@wleuthold avatar
You have to push the round knob in once before turning it to "on"
After pressing it in, it should turn easily.
Like my 2023 does.
Bill
@kawzak avatar
New 2023 BV-400
@kawzak avatar
New 2023 BV-400
If the knob is in the off position,the knob has to be pressed "in" first, then turned to the right to the run position. Then press the start push button on the right handlebar. If the knob is in the locked position( all the way to the left- handle bars locked to the left), then it still needs to be pressed "in", then turned to off position then continue to the run position. Of course all this requires the FOB to be within 2-3 ft from the scooter glovebox area. And this with a known good battery in the fob. As the last poster said get or download the owners manual. Also u-tube vidios from Scooterwest and Robot ( a tech that works there) explains it all.
It sounds so simple, just press in and then turn. But it doesn't always work for me, and after about three tries I turn the knob slightly to the left and then it usually works.
@mitleider avatar
@mitleider avatar
Thanks to you all for taking time from your day to offer help! This is an amazing community of kind-hearted people. I'm going to follow the collective advice now, give it a try u til we develop a reliable technique
I've just checked the owner's manual - I can't see where this fairly essential instruction is given. BICBW...
Vespa GTS 300
Vespa GTS 300
Got it, thanks GTS_G_R.
[ Time: 0.0085s ][ Queries: 4 (0.0023s) ][ live ][ 343 ][ ThingOne ]
