@charliewilko avatar
LX50
LX50
I have noticed my rear break on my 2006 Vespa LX50 locks up when I have pressed onto my rear break. I did some tests on it and every time I press down on my rear break, the cable doesn't get loose it just stays very tight which causes horrible noises when trying to move off.
What could this be? Is it as easy as adjusting the cable or is it more in depth?
@srd0060 avatar
2022 Super tech/ 91 PX 200e/97 PX 200e
@srd0060 avatar
check your rear brake shoes i dont think you have any left..
LX50
LX50
Where about on the bike is it located? And is it easy to do myself?
@srd0060 avatar
@srd0060 avatar
inside the rear hub, you may need a mechanic or youtube.
?si=2o6B_1K8E8gQ0zbz
LX50
LX50
It seems simple to do from what youtube has said. Is this the biggest chance that it could be? Or could it be anything else?
LX50
LX50
This is not what ive seen on YouTube, as that one talks about the break pads and not about the brake shoe which is what I have found:
@srd0060 avatar
@srd0060 avatar
it may or may not where do you live, is there a scooter shop close by?
@jkj-fz6 avatar
@jkj-fz6 avatar
The pads are on the disk brake on the front wheel, brake shoes are inside the rear wheel hub. The video here shows the brake shoes on the rear wheel.
I think the rear wheel will have to be removed to see what's wrong with the brake.
@wbdvt avatar
@wbdvt avatar
Exhaust and rear wheel need to be removed to inspect shoes
How many miles on scooter?
LX50
LX50
Yes it doesn't seem too hard to do.
It has 15,724 miles.
@jkj-fz6 avatar
@jkj-fz6 avatar
You'll need a set of metric sockets, and though the video doesn't show it you should use a torque wrench to reassemble the wheel and exhaust.
@wbdvt avatar
@wbdvt avatar
Have you ever inspected the brake shoes on the rear and pads on the front?
LX50
LX50
I never had, I got the bike last year in July.
@wbdvt avatar
@wbdvt avatar
So you have done no maintenance on it?
LX50
LX50
Before I had the bike it wasn't used very much, only once every 2 weeks just so it can keep it going and he never used to put much fuel in it so it didn't get dirty. Ever since I have had it, I have changed the rear and front bulb, replaced the exhaust due to rust, changed and clean the air filter every 3 weeks, changed the starter motor and alternator, cleaning the carb, rear wheel change.
I doubt it's the brake shoes (though it might be) but my chief suspect would be the Bowden cable itself. I bet it's had some moisture in there, and has rusted to the point where it doesn't want move freely. Easily diagnosed, as unhitching the brake cable will be the first step to removing the shoes anyway...
[ Time: 0.0128s ][ Queries: 3 (0.0035s) ][ live ][ 343 ][ ThingOne ]
