Just ordered a replacement starter relay for my mp3, picture shows no screws, anybody know if it comes with screws?
Don't see them as an option to order in the parts diagram.
Wayne B
Posts: 8956 Location: Ashburn, Va. Home to the Internet |
Don't see them as an option to order in the parts diagram. Thanks Wayne B |
Looks like they do not come with screws unfortunately. Now I have to track down some really short screws.
Posts: 1733 Location: Vermont |
Have you tried an Ace Hardware store? They usually have a good selection of metric screws.
wbdvt wrote: Have you tried an Ace Hardware store? They usually have a good selection of metric screws. |
Posts: 46190 Location: Pleasant Hill, CA |
WEB-Tech wrote: I'm going to try hardware stores first, most likely going to have to go to Fastenal, as the screws are really short. |
jimc wrote: You can always cut down longer ones - hacksaws are very useful. |
Posts: 4815 Location: Twin Cities, Minnesota |
Run a nut on the screw before you cut it. Then when you back off the nut it helps restore the threads.
Pliers with screw cutters are useful too. Does anyone know if they're made with metric threads?
Have a friend that builds custom motorcycles, if I can't get it done, I'll stop by his shop and he'll do it for me.
https://motorelic.com/ He built a motorcycle that looked like a large spider bicycle with what I think was a 650 triumph motor in it.. |
Here's one he did in 2022
https://www.facebook.com/1285816333/posts/10228121415002386/?mibextid=rS40aB7S9Ucbxw6v |
what happened to the original ones? my parts fiche shows nuts to hold that part on part# B005195 Self locking nut M3 but my bike is a 2021 so its probably different.
scottk wrote: what happened to the original ones? my parts fiche shows nuts to hold that part on part# B005195 Self locking nut M3 but my bike is a 2021 so its probably different. That was done trying to connect the two battery leads without disconnecting the multiple wire connector. Making it hard to line the screws up. The original mp3 starter relay had studs and nuts instead of screws, which made it much easier to get the cables connected. Have no idea why they changed the design to screws instead of studs. I'm sure it was a cost saving issue. |
JKJ-FZ6 wrote: Pliers with screw cutters are useful too. Does anyone know if they're made with metric threads? https://www.amazon.com/dp/B00OYQ56EG/?tag=atomicindus08-20 Like others have said screw a spare nut on all the way then cut/grind/file or what ever then back the nut off to straighten out any damaged threads |
I've been thinking about it, if I'm having to cut bolts to the right length, I might as well just make studs. They were much easier than the newer style screw. So I'm just going to cut off screws and make them in to studs. Use a double nut set up on the end to screw them in and tighten them up.
Positive
Received the new relay yesterday, went out to my shop to find a long bolt use that I could cut off. It's 6 mm by 1.25 pitch thread. Which isn't common. Fastenal doesn't even carry it. Found some on Amazon. Had to order 10.
Will be here between May 1st and May 5th. 🙄 |
