I'm in the final stages of the rebuild of my LML, part of which included replacing the 10 year old hardened fuel pipe.
The new pipe went on fine, taking the same route as the old one (under the oil tank clip thing). The tank seemed to drop back into the frame with the minimum of force, so I don't think that anything got pinched. However, when I add 1 litre of fuel to the tank and switch the tap from off to reserve, the fuel barely reaches the banjo. Is this normal? The fuel fills the pipe to within a couple inches of the banjo, but not enough to make its way into the carb.
I made a simple test of removing the pipe from the banjo and dropping it straight down into a container. The litre of fuel took 1 minute 10 seconds to drain completely, is this within specs? It's a fast-flow tap and was working fine with the old pipe, so I don't think it's at fault.
I cut the new pipe as short as I could without putting any tension on it. Maybe I could cut another inch off, but that would be all. As it stands, it would seem that the last litre of fuel in the tank isn't going to be of any use. Or with the motor running, is there a kind of siphon effect that will draw the fuel through the pipe?
