@rallygeek avatar
@rallygeek avatar
Hi all - a question for the carb experts
I am rebuilding my shb 19.19 carb. I have the gasket kit for it but I am unsure what other parts have too much wear and need to be replaced.
First is the throttle slide, it has visible wear marks on it. I assume it needs to be replaced.
Second is the various jets, I have soaked all the parts in acetone for 24+ hours so that should have cleaned the gunk from them. Is that usually enough? Can I just blow air through them and re-use them?
Paul
Throttle slide with wear
One of the brass jets (possibly air corrector)
Choke jet
Choke jet
@roland87 avatar
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
@roland87 avatar
Better to replace. But to be honest on my 19.19 slide looks similar or even worse when I got the carb. Was work for six years without any issues and I'm sure it will be work further but I got another carb.
Yes for sure.
It is the idle jet.
@rallygeek avatar
@rallygeek avatar
Thanks. I took it to local Vespa shop and he said it's more of a rub mark , there is no groove. Following his advice I am going to use the existing slide and clean up all the jets as much as possible. Am replacing all the seals and gaskets.
@rallygeek avatar
@rallygeek avatar
After a good clean and replacement of the float, float pin, rings and gaskets etc I have managed to finish my carb rebuild.
Rebuilt
Rebuilt
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
now to make it sit on the manifold and somehow not leak....
and it's also that time you have to decide which side the felt ring goes on - the debate has never been fully resolved!
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
@rallygeek avatar
@rallygeek avatar
Ok will cross that bridge in a while as I have a few jobs to do before I get the engine back in the frame.
I am using the original manifold and carb so they should match well. Will let you know when I try and put them back together.
'74 50s x3 '87 PK125XL '92 PK50XLS Plurimatic - & - '58 AllState '68 Sprint '66(?) Super125 '72 DanMotor Super150 and '04 Bajaj LML hybrid
Goes on last, just before the carb. At least that what I found on all those I've taken apart w/ at least one probable virgin.
Also get a new RED float needle if you didn't replace that, and you might wanna burnish its brass seat with a souvlaki skewer for extra insurance against leakage.
Look here: Random tricks, share your best little tips & shortcuts (Post 1823915)
@rallygeek avatar
@rallygeek avatar
Have been delayed in finishing this off. I managed to accidentally pull the cable inners down into the tunnel of my et3 and spent a whole afternoon trying to get them back in place. I am now ready to time the engine before installation.
Thanks for the link, that explains the 'souvlaki' stick process.
One last question, are there different size choke cables for a smallframe? It is really difficult to fit the brass plunger to the end of the cable with the adjuster installed.
@roland87 avatar
@roland87 avatar
There is 146mm and 133mm sleeve lengths but cable in both is 203mm.
And it is easy to fit plunger.
[ Time: 0.0132s ][ Queries: 4 (0.0068s) ][ live ][ 318 ][ ThingOne ]
