Hi all,
I've been trying to get the fuel gauge to work on my P2, to no avail.
First, some specifics: the speedo is a PT Danmotor unit from an Exclusive 2, to which I have no wiring diagram (if anyone does have a diagram to share, I'd love to see it by the way). The bike is a spanish 200ds (P2 with no turn signals), and the electrical circuit was made by myself (everything else works, except the oil level warning system, but that's less urgent ).
The speedo was a brand new aftermarket unit when installed, so I'm assuming it was functional. It worked once with a battery (showing full, half full and empty) when tested while building the bike, but once built, and ever since, no more gauge!
The sender unit is new and has been tested, and I've checked the continuity in all the relevant wires (ground, gauge, and reserve light) all the way to the speedo. (the one in the picture is the old one, shown just to point to the wiring).
The issue seems to be within the speedo itself, but my limited self-taught understanding of electrics has me stuck, as to what or how to test to check if it works, and if not, how to break it down to the faulty component.
As on most other Vespa speedos, the gauge unit has 3 screws which attach to the circuit. So ground, 12V, and wire to the sending unit. There is a 4th screw with no wire attached.
I tried connecting a 12v battery to the (supposed) ground and 12V plots, which should make the needle go to full if the sender isn't connected (I tried with and without the sender, and the needle didn't budge). I'm identifying the plots solely based on their resemblance with other Vespa gauges, and an online translation of the chinese characters on the housing, so not 100% sure.
While testing continuity, I tried testing from gauge plot to gauge plot, just in case it might be relevant somehow:
between ground plot and 12v plot: 215
between ground plot and "to sender" plot: 128
between 12v plot and "to sender" plot: 86
Not sure what that means, if anything.
