Just a heads up that today (Sunday 4/21) site availability might be a bit sketchy. I'm planning on switching over to a new server, which has been simmering for several weeks now. The new server is really new, with a new operating system, lots of updated software, new cacheing systems, and an entirely new network architecture.
Which probably means that the server will be misbehaving out of the gate.
At the very least, there are likely to be some DNS propagation issues.
I'll give you another heads up when I'm closer to making the switch, I don't have an exact time right this moment.
⚠️ Last edited by jess on UTC; edited 1 time
Updated title and details. I still don't have an exact time, but I am on course for a server swap today. I am currently putting all the pieces in place, requesting new certificates, and trying to make sure things go as smoothly as possible.
But there will still be bumps, I'm sure.
I'll keep you updated.
Thank you. I need to buy you a bunch of coffees for all the years I have been on here.
You don't need to do anything of the sort. There's no obligation whatsoever.
But it would be appreciated if you do.
I'm going to (attempt) the server switch at 1:30pm today, Pacific Daylight Time. That's 8:30pm Universal Coordinated Time, or 9:30pm British Summer Time.
(I hope I did that right).
The switchover will probably be slow due to DNS propagation, as technically the IP address will change. However, DNS propagation is a lot faster than it used to be, so... who knows?
We're about 40 minutes away.
Okay here we go.
I've made the change to the DNS records, so now we wait.
My first attempt to pull up the site actually did get the new site, but then it went back to the old site. Not sure what that's about.
You'll now you're on the new site when you see the word "New!" in the upper right corner of the masthead, like so:
Okay, the DNS changes have reached my home internet.
Your mileage will vary.
One more bump: I have to configure the bit that forwards www.modernvespa.com to modernvespa.com, and it's been giving me fits all morning. I'm going to try it again now that the site is live and see if it works.
@marret avatar
@marret avatar
Seems to be working for me. Thanks for all.
Done. I think it's working (DNS propagation aside). The new IP address for the server will be slowly published to all the DNS servers around the world over the next hour (or hopefully much less).
This new server is:
- Running on a new OS (Amazon Linux 2023)
- Using PHP-FPM (instead of mod-php)
- Using php8.2 (upgraded from php7.4)
- Now using php opcode cacheing
- Sitting behind a CloudFront distribution network, which is the termination point of the HTTPS/TLS/SSL connection
- Now available over IPV6 as well as IPV4
- Supports HTTP/2
And countless other changes made over the last few all-consuming weeks.
There are still likely to be issues with the new server that I haven't become aware of yet. I'll be watching the logs for signs of trouble, but if you see something amiss (like a white screen, in particular) then give me a shout here in this thread.
I spoke too soon about IPV6. While technically it's supported, the forum software itself (a product of an IPV4 world) is having trouble with the client IP addresses. I've turned off IPV6 for the moment.
Lots and lots of problems spewing in the logs. I'm not sure how much of it is visible, but I am plugging holes as fast as I can.
@madison_sully avatar
New!
20 years of sloppy PHP has caught up with me. The new version of PHP is quite a bit more strict, and... I am ashamed.
Facepalm emoticon
Facepalm emoticon
Go on - 'fess up a dirty story...
@tripo avatar
2016 GTS 300 Settantesimo Grigio Pulsar
@tripo avatar
I see NEW!
There's no story, per se. Older versions of PHP were generally silent about casual use of an undefined variable. It was fairly common PHP practice (for years and years) to see statements like:
if ( $flag )
   // do something
...when $flag hadn't been set. Often, it was quite deliberate -- set a variable to something when it's appropriate, and leave it undefined otherwise. PHP has never been what I would call an exacting language, or a particularly pedantic one. Quite the opposite.
But starting with PHP 8, the keepers of the language have decided that PHP is a serious and pedantic language (hah) and have started raising a warning whenever you reference a variable that hasn't been explicitly defined. Which is all fine and good and all, but it isn't the way it's been for a couple of decades of PHP, and so there is a lot of code written with different assumptions. And I am having to fix all of those assumptions (at least, all the ones I haven't already fixed) now, today.
Most of these are innocent and even deliberate cases of an undefined variable. But I'm finding a few where it wasn't intentional, too -- places where code got ripped out but a few stray variables were still referenced in nearby code, for instance. Those are genuine errors. Generally harmless, but still errors.
I am slightly amused to see that there are still a trickle of requests going to the old server. I'm reasonably certain that DNS should have propagated worldwide by now, so in all likelihood those few stragglers are accessing the site by IP address, and not by name. But since the old server (and the new one) refuse connections that don't include the hostname (modernvespa.com) these straggler clients are almost certainly bots, and in fact they are all anonymous and don't read as humans.
And that gives me an idea.
@shebalba avatar
@shebalba avatar
I kept clicking on the New! hoping it was an easter egg.
Then I thought it was a bug that I found and could get a bug icon..
Then I remembered this topic. Facepalm emoticon
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
I did not notice any difference.
All works fine.
310 GTV Officina 8
310 GTV Officina 8
Jess as a newbie I doff my cap to you for the diligence in keeping this very informative and friendly site up and running👍👍
Ha, I didn't look at this thread until after the change, so found myself looking around for anything abnormal.....and didn't see it.
The chance for abnormality is still high. I'm still fixing bugs in the background.
@bajarob avatar
@bajarob avatar
When I click the "Mark All Read" button on the forum index page it gives me a white screen that says file not found in the upper left corner in tiny letters. That button works for me on all the other pages.
Thanks for the tip, I'll investigate.
It should be fixed now. The old code didn't work with the new server layout, and I missed it. I moved that code to a new location (along with other mark read functions) which should work much better.
For finding and reporting this forum bug, I hereby bestow upon you the MV Entomologist Award. Wear it with pride, sir.
@bajarob avatar
@bajarob avatar
Awesome! All thanks go to you though. Your work boggles my mind!
@starreem avatar
@starreem avatar
No bumps in the road for me. I noticed "New!" in the upper right corner a few days ago. No other issues for me. I've done a few searches. Not much else. I have a huge amount of respect for your dedication over the years to make this a very usable forum.
@kawzak avatar
New 2023 BV-400
@kawzak avatar
New 2023 BV-400
Thank you for all you do.
@aiosi avatar
@aiosi avatar
Jess, FYI
No biggie but I did get a 404 error when I tried to reach the site from my Favorites.
If I typed in the address manually (www.modernvespa.com) it opened OK.
Turns out my Favorite was pointed at https://modernvespa.com/forum/index.html
I just edited the Favorite to be www.modernvespa.com and now it redirects me to https://modernvespa.com/forum/ which is OK by me.
Thanks for all you do!
Yeah, sorry about that. "index.html" has never really been an actual file, and the old server probably had some redirect somewhere that made it work. I'll see if I can put in a redirect. In the short term, your instinct -- to change your favorite -- is correct.
One minor point -- we don't use www in front of modernvespa.com. If you use it, you will get forwarded to the non-www version, which will just slow you down.
@bluside avatar
2020 GTS 300, 2011 LX150ie
@bluside avatar
All looks good here.
Jess, your talents are mind boggling.
Mind-numbing, maybe.
@olde_rider avatar
Primavera 150S, and GTS 310
@olde_rider avatar
Ditto!
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
I don't know whether that's a bug or intentional:
I have two notifications about replies in my topic. The link in the older notification works, the link in the newer notification leads to a 404 error. It seems that the post has been deleted again. I would expect that either the notification would then be removed or that the error message would explain that the post was deleted (and possibly the error message would at least lead to the thread). So it just looks like a "broken link".
It's not so much intentional as much as just an edge case that isn't (currently) handled correctly. You're correct in your assumptions, and even your expectations, but the code is not currently smart enough to handle it.
I'll add it to the list, though.
@shebalba avatar
@shebalba avatar
I have an iPhone 13 Mini. I don't know if this has anything to do with the update, but this is how my screen formats. With the header off center from the topics. I don't recall this always being the case.
It's just the General Discussion main screen. Everything else seems fine.
It also doesn't bother me, just thought I'd share in case it's important.
Nope, not related to the update. Someone put a link into a topic title, which forced the layout to go wonky. I've edited the offending topic and moved the link into the body of the topic.
Should be better now.
@safis avatar
@safis avatar
Getting regularly a 504 error after the switch...
[ Time: 0.0205s ][ Queries: 4 (0.0042s) ][ live ][ 343 ][ ThingOne ]
