Check spark, fuel, air, battery and compression. Results:
- Spark: Bright. See pic and video link. Hopefully the video link(s) to my dropbox work ok.
- Fuel: Nice looking spray cone. Don't have a way to measure the pressure but the pic and videos provide decent visual checks of injector squirting and pump priming.
- Air: I can lightly feel air drawn in while trying to cover the throttle body intake by hand.
- I also sprayed short bursts of starter fluid into the intake while cranking the engine. Nothing...
- Compression: I stuck the tip of my finger on the spark plug hole and pushed it in pretty good. First compression stroke pushed the finger right off the hole. I don't have a compression gauge for an exact measurement.
- Battery: To eliminate any questions (voltage, cranking speed) around my aging battery, I installed and charged a new battery. You can hear the cranking speed in the spark plug and pump videos.
- Observation/question about the spark and injector videos: It seems that there is a repeating pattern of several impulses followed by a very brief pause, impulses and pause, impulses and pause, etc. I noticed this for the spark as well as the injector. Does anyone know if this is normal?
- Additional info: When this crank but no start first started happening about a year go, it was rare and seemingly random. It would happen maybe one out of every ten times starting. At the end of last season, it eventually became permanent. Ie it happens every time now and does not start anymore at all.
Any suggestions on where to go from here besides hauling it to the closest dealer (150mi one way)? Thank you!
Spark while cranking video:
https://www.dropbox.com/scl/fi/7m7a5bge6d38457aqp4pq/IMG_2727-1.mov?rlkey=700g7jxqbv0v4lp2o5j008njt&st=a9xfeo5b&dl=0
Injector squirting while cranking video:
https://www.dropbox.com/scl/fi/w65sopmtl7v8swecignt3/Fuel.mov?rlkey=vzen3fboy9ekuzz00doih6evg&st=dylli2o1&dl=0
Fuel pump priming with key on:
https://www.dropbox.com/scl/fi/2t3zjc35yj9o23v8rpr5k/IMG_2725.mov?rlkey=z6k93wpqcslyvv9gocb5l25wm&st=23lkz34k&dl=0[img][/img]
⚠️ Last edited by PeoriaLX on UTC; edited 2 times
