Aprilia SR50
Aprilia SR50
Hello-
I need help identifying this engine and which scooters it come from, dont even know the size but from the carb it might be a 125 or 150cc. [/img]
@safis avatar
@safis avatar
Not a Vespa engine, looks like a Minarelli / Yamaha / Suzuki type engine, probably started as a 50cc…
By the looks of it, maybe it was on an ATV??
Aprilia SR50
Aprilia SR50
Thanks, the seller said it's a Vespa engine, idk. He did said he plan to put it on his ATV then changes his mind.
@greasy125 avatar
@greasy125 avatar
mos def not a vespa engine.
likely Yamaha or some minarelli variant.
@buggsy avatar
@buggsy avatar
The only PHBL25's I've come across is Delortto open mouth carbs, is there any other serial numbers showing.
Also you would see Piaggio stamp marks.
It's a Minarelli. Came out of an ATV.
Aprilia SR50
Aprilia SR50
Here's a few more pictures with the only # on the whole thing.
Still a minarelli. Still came out of an ATV.
Here's the simplest way to know if a two stroke scooter engine is a Piaggio:
Count the bolts holding the intake manifold onto the engine. Are there two? It's a Piaggio. Are there more than two? It's not a Piaggio.
And if it has four bolts holding the intake manifold onto the engine, here's how you can tell if it's a Minarelli or a Morini:
Does it mount from the top of the engine? It's a Minarelli.
Does it mount from the bottom, like a Piaggio engine? It's a Morini.
So if your engine has four bolts holding the intake manifold on, and mounts from the top, it's going to be a Minarelli.
Aprilia SR50
Aprilia SR50
Thank you again Motovista-
So I got a 90cc Minarelli engine, from searching around my is a short case. Maybe one of these day I'll fine a donor scooter for that engine. Ben
[ Time: 0.0137s ][ Queries: 4 (0.0040s) ][ live ][ 343 ][ ThingOne ]
