ET2
ET2
I have a 03 ET2 and it has been really hard to start this spring on cold mornings. What is doing is I have to roll it over 20-30 times before it will finally kick off and it still takes it a minute to come up to idol. Once running though, it runs great.
I am assuming its the automatic choke but thought I would make a quick post to have a couple others confirm. Much appreciated in advance.
When did you last change the spark plug?
ET2
ET2
I am not sure but it has not been that long ago and certainly not many miles ago. I have been fighting with gremlins for a little while now. The fuel tank tap was bad, got some trash in the carb after that. I got those fixed and then the starter relay went out. Now that its all back together, I have this.
I have what seems to be good spark, but a plug is a easy place to start.
@wbdvt avatar
@wbdvt avatar
Tight exhaust valve?
It's a 2-stroke. Hint in the name.
@wbdvt avatar
@wbdvt avatar
Ah I missed that. Old age is a bear!!
[ Time: 0.0109s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
