Hello friends, I ordered rings and was checking the gaps, when I noticed an inconsistency from the gap where the rings are in the middle of the bore just above the ports, vs the gap near the top end of the cylinder.
This suggests to me the cylinder is 'worn in'. Is that the case or is this 'normal'? According to some posts, ring gap should be measured closer to the middle of the bore, but if the rings travel to the top and they expand due to heat, I imagine that the ring ends will be forced together and cause a 'collision'.
The middle of the bore one ring measures at 0,35, but near the top end, it measures ~0,05. Quite a difference
Should I replace the cylinder and get a new kit? (piston, rings, cylinder) or can I get the bore machined, then upsize the piston and rings?
[/img]
